Pages: 1 [2]
Author Topic: Boolean operations plugin is here! (new version!)  (Read 18097 times)
bamman62
Re: Boolean operations plugin is here!
« Reply #15 on: August 07, 2009, 02:06:20 am »
:D I've wanted that for a long time.
Thanks!
Maxfield
« Reply #16 on: August 07, 2009, 10:00:58 am »
Kubajzz, thanks for the script, but I can't get it to run.
The debug output gives the message:
Compiling "F:\Anim8or\Script\version2\Boolean Intersection.a8s":
error on line 23: undefined indentifier 'attribute'
error on line 23: ';' expected
23 lines 2 errors
There's a similar message with each script. Is there something special I need to do in unzipping and installing the files, perhaps?
  • Flying Platypus
« Reply #17 on: August 08, 2009, 03:21:08 pm »
I guess this happens because you are not using the latest version of Anim8or. Try downloading version 0.97d:
http://www.anim8or.com/download/preview/index.html
Maxfield
« Reply #18 on: August 09, 2009, 06:37:15 am »
Thanks, Kubajzz. I recently reinstalled Windows and didn't realise I'd got an old version of Anim8or off my DVD-ROM. Now your script works - and beautifully. Anim8ors have been waiting a long time for Booleans!
  • Flying Platypus
Re: Boolean operations plugin is here! (new version!)
« Reply #19 on: August 09, 2009, 10:36:59 pm »
A new version is out!
Direct download link
I fixed several small bugs including the texture coordinates problem. The script is a bit more reliable, although it is still not perfect.
Enjoy!
Suppastar
« Reply #20 on: August 10, 2009, 06:33:29 pm »
I have waited so long for this!  It may not make a 100% perfect cutout, but it doesn't need to to be either. Why? The time saved fixing only a few misplaced faces/lines is no where near the time spent having to manually cutout a circle, or what ever, from a already modeled mesh.
Although it couldn't hurt to be improved just a little bit on the 'reliability' factors. I thank you from the bottom of my heart Kubajzz and all who helped. It's people like you, that know .Asl/coding, that are making Anim8or a more perfect tool everyday.
neodelito
    • ModuloSoporte
« Reply #21 on: August 12, 2009, 01:25:41 am »
hey man.. your are a master,.... thanks for your work...
(is not 100% exact but work fine for me..now make a png and hair plugin  (i make a hair external prog but i cah export the final model.. Buaaa))
I
Pages: 1 [2]
