Pages: [1] 2
Author Topic: F8ce primitive  (Read 12124 times)
BOB_I_Ts
    • Anim8rOrg
F8ce primitive
« on: March 27, 2010, 09:22:36 pm »
F8ce 3d character designer plugin for anim8or v0.97d + which allow user to change multiple body parts of the model using the attribute editor
f8ce version 7
update
reduced polygon count
tweaked proportions
add gender 0 for male 100 for female pre-set into the parameter properties
add skull tag (making it 61 variables :o )
new tool button
Plugin zip includes f8cetester.an8 to preview some random characters made when i was testing it
Attribute tags (all lower case)
skull
brow
eyeoffset
eyescale
cheek
ear
nose
nostril
upperlip
lowerlip
jaw
chin
neck
chest
upperarm
lowerarm
gut
pelvis
upperleg
lowerleg
How to edit f8ce:
A)Goto Object>Attributes ...
B)Click New button to bring up the name tag box
C1)Type in one of blue name tags above remember all are lower case fonts
C2)click new each time to add an attribute to active object
D)In the TYPE tab enable "point", 3 value box's should appear box from left to right are equal to x,y and z coordinate of each taged region
E) The plugin attributes go by percentages from 0.0 to 100. how ever there is no restriction limit you can even use negative percentages as well
F) At present there is a refresh issue with attributes but you can .
Fa)double click the f8ce model and click ok button to refresh
Fb)select f8ce model and enable non-unform tool then adjust the gender parameter along the x axis
Fc) delete and recreate f8ce model
Commen issues
Positive if you delete f8cea then recreate f8ce plugin the attributes stored will be remembered so if you delete model and save the file the shape is not lost
Negative : loading save file the attribute needs to be refreshed by step F above
Negative remember attributes are not supported with undo command
Negative Converting f8ce for unknown reason can cause anim8or to crash ,A solution is to export to 3ds then reimport back
debug(reason for crash found 0 uvCoords  "texcoords {}" is missing from an8 save file after convert parametric to mesh) ! so when i add texture coordinates to script it should no longer crash
Feedback
Any feed back on its improvement is welcome , hope you enjoy it ;)
« Last Edit: May 08, 2010, 10:28:40 am by BOB_I_Ts »
Re: F8ce primitive
« Reply #1 on: March 27, 2010, 10:13:02 pm »
This looks great!  I'm loving the progress you're making on this.  I can see that it could be a very useful tool in the future as a basemesh.  Keep it up mate!
  • Flying Platypus
Re: F8ce primitive
« Reply #2 on: March 27, 2010, 10:48:59 pm »
Great progress! I can't wait to see this project finished.
  • Neirao
Re: F8ce primitive
« Reply #3 on: March 28, 2010, 05:45:44 pm »
very cool plugin, BOB_I_Ts!!
when finishing he is very usefull for Anim8ortrs!!
BOB_I_Ts
    • Anim8rOrg
Re: F8ce primitive
« Reply #4 on: March 31, 2010, 11:22:51 am »
Thanks for positive comments
nose parameters preview
top  left to right oriental nose (cage) african nose = (A) egyptian nose = (B) and caucasian (C) based the nose's from clicking some random faces on the art.sk website
all rest are mixture between the 4 top
« Last Edit: March 31, 2010, 11:27:45 am by BOB_I_Ts »
Josmic8or
  • anim8t & celebr8t
    • JOSIAHSTUDIOS
Re: F8ce primitive
« Reply #5 on: March 31, 2010, 08:59:19 pm »
Whoooa!!  :o  :o  :o  :o  :o  :o
This script can be helpful alot!!
Can't wait for it to be completed!! :)
BOB_I_Ts
    • Anim8rOrg
Re: F8ce primitive
« Reply #6 on: April 01, 2010, 01:07:27 pm »
updated script
parameters : nose A nose B Nose C mouth A mouth B mouth C jaw A jaw B jaw C
you can edit each parameter by double clicking face or edit each A,B and C as a group using non uniform scale
remember parameters are 0 to 100.% shared between 3 using 100% in all 3 will cause mutation
plugin is still WIP
wacky blend
  • Witchy Woman
Re: F8ce primitive
« Reply #7 on: April 11, 2010, 11:55:50 am »
Great job Bob, you have a lot of time on your hands to make a script like that.
WB
BOB_I_Ts
    • Anim8rOrg
Re: F8ce primitive
« Reply #8 on: April 11, 2010, 05:28:02 pm »
thanks guys
I was known as speed modeller im sure Raxx can back me up on that also technically i only wrote small portion of the script and asl exporter did all technical numbers for me "i did not type in a single coordinates" :o (f8ce is only 1 low poly model with morph targets)
just check trinity export script to see how much time it really takes  ;D the f8ce-dev script is based off trinity apart from it can read infinite amount of morphs instead of just 3
sorry delay in update but training a siberian husky atm but soon as its safe to leave it on its own with out it chewing every thing in sight i will try complete the model
some changes i have been thinking of
~ instead of going from morph A to B to C should i change method into a morph X morph Y morph Z of each region in attribute editor
~ i dont think there is any default-max-min restrictions in attributes !
~ can attributes and controller scripts be linked !?
~ parameter i should leave key facial features as parameters like nose type, lips type,!..skull type fat , thin,smooth angle ect
~ im going to leave out genitalia
~ do nipples class as nudity ?
~i haven't thought about attributes and making them up as im typing just now
brow up/down y
brow narrow/broad x
nose y scale
nose z scale
nose narrow/bloated x
nostril narrow/wide x
nose tip piglet/drooped y
cheek raised / lowered y
cheek narrow/wide x
upper lip thick y
upper lip forward z
mouth wide short x
lower lip thick y
lower lip forward z
chin short /bruise foresight y
chin in / out  z
chin square / round x
jaw narrow broad x
jaw forward/back z effects chin positions to !
shoulder broad / narrow x
should beefed / flat z
chest (ribb cage) y scale
spine curved stiff z
gut flat / bubbled z-x (edge loops set for six pack but !left out for modellers preference to model inset them)
hips x
rear end z
rear end y
crouch !... x region space between leg bulge z droop y
upper leg y
muscle z-x
lower leg y
muscle z-x
ankle x
foot z
upper arm x (!model in scare crow position)
muscle z-y
lower arm x
muscle z-y
hands .... this list may change as problems unseen problems maybe found
~parameter
thin - fat
eye presets unsure how to approach eye editing yet ?
nose presets like we have already
lip presets fine tweek to V shape on upper lip !
smooth angle (mesh properties)
yes you are wright this may take some time haha , ill probably start topic in WIP forum so community can assist in the base models completion after all its intended for the an8 community
wacky blend
  • Witchy Woman
Re: F8ce primitive
« Reply #9 on: April 11, 2010, 09:52:41 pm »
Hey Bob,
I don't know if this helps. I use make human a bit which is similar to what you are doing for this script for Anim8or.  If you take the generic mesh of one extreme and export it to your ASL exporter.  Then run the other extreme through the same way, you would have your 0 to 100%  Thin to Fat.  I don't know if that is a good short cut or not since I don't know much about the ASL exporter you spoke of and I have no idea on the script language.
Make Human can export to OBJ and I don't believe it has a low poly setting.  I currently use version 0.9.1 RC1 because the newer version was missing features I liked.
Wendy
captaindrewi
  • errm...errr?
Re: F8ce primitive
« Reply #10 on: April 11, 2010, 11:39:47 pm »
i realise  this is a work in progress
but if i try and subdivide the resultant face mesh, anim8or crashes
is that universal?
Re: F8ce primitive
« Reply #11 on: April 12, 2010, 02:00:34 am »
note 2 for unknown reason anim8or crash when converting to subdivided
Josmic8or
  • anim8t & celebr8t
    • JOSIAHSTUDIOS
Re: F8ce primitive
« Reply #12 on: April 12, 2010, 06:50:12 pm »
It's currently a work in progress but one trick I used to get it subdivided is exporting it as 3d studio then importing it back in anim8or and then u can subdivide it.
captaindrewi
  • errm...errr?
Re: F8ce primitive
« Reply #13 on: April 13, 2010, 06:08:42 pm »
sorry i failed to read the subdivision bit at the top of the thread Hiho.
thanks for that tip Josniv8or but sadly the 3ds trick doesnt work for me.
it maybe a vista glitch
no worries.
captaindrewi
  • errm...errr?
Re: F8ce primitive
« Reply #14 on: April 14, 2010, 10:57:36 am »
worked a treat KREATOR ,nice to explore the scripts possibilities.
it's a wonderful project Bob-I-T .
Pages: [1] 2
