Author Topic: OBJ File Exporter Script For Anim8or To Export.  (Read 6335 times)
Josepsh
« on: August 01, 2012, 02:57:49 pm »
How To Export My .45 Hand Gun..obj From Anim8or To Test In GTA San Andreas For PC.
« Last Edit: August 01, 2012, 03:24:07 pm by Josepsh »
Re: OBJ File Exporter Script For Anim8or To Export.
« Reply #1 on: August 02, 2012, 02:40:33 am »
At the top bar, do this:
Object => Export... => Save as type: Wavefront (*.obj) =>
you probably know what to do after that.
Josepsh
« Reply #2 on: August 02, 2012, 03:16:47 am »
No what to do after that?
« Last Edit: August 02, 2012, 03:21:22 am by Josepsh »
RudySchneider
« Reply #3 on: August 02, 2012, 03:27:27 am »
davdud101 ---
While specifying how to export an object file may be the most obvious response, I'm not certain that will really do Josepsh much good because, according to this site (http://www.gtamodding.com/index.php?title=Model_file), GTA requires  models to be in .dff file format.
G
Josepsh
« Reply #4 on: August 02, 2012, 03:52:08 am »
Thank's davdud101. ;D.
I Think I Did It First I Put The File Into Img Tool. Img Tool Will Rename
The File For You But You Have To InPut The Name And .Dff Ex. In The Name. Right?
lppena
  • Anim8or, does a body good.
« Reply #5 on: August 02, 2012, 03:49:16 pm »
It all depends on what you want to use it for Joseph. You also have other formats like 3DS and the many other 3rd party model exporters. Plus you'll need a utility to view the model outside of Anim8or. I use an old  free one called Discreet's 3D Exploration to both view and convert models to other formats.
Josepsh
« Reply #6 on: August 02, 2012, 04:34:38 pm »
For A GTA San Andreas As A Mod.
« Last Edit: August 02, 2012, 09:52:05 pm by Josepsh »
lppena
« Reply #7 on: August 03, 2012, 12:27:47 pm »
So is Img Tool a obj to dff model converter?
