Author Topic: Sequence editor Problems 0.97E & F  (Read 2889 times)
« on: November 01, 2013, 05:55:06 pm »
have problems with stopping any sequences with 0.97E and 0.97F
In so far as the sequence stop button ghosts the screen, with message "Anim8or is not responding"  escape key does not return to edit status
Also does this with looping a sequence.
Re: Sequence editor Problems 0.97E & F
« Reply #1 on: November 02, 2013, 01:14:22 am »
I can see a problem when looping a sequence - pausing with the space bar and resuming limits the range of the replay.  I can't get it to hang however.  What OS are you using?  Can you send me a small project that shows the problem?
« Reply #2 on: November 02, 2013, 09:27:52 am »
hello Steve,
Here is a screenie of the hang in 0.97F
Does the hang when I use the spacebar or video stop button, using Win7 ultimate.
since the problem, I have placed the program into compatibility mode.
 Run in Windows XP( Service Pack 3)
Disable Visual Themes, and Disable Desktop Composition. Which seems to have solved the problem so far
Did you still want the .an8 file?
« Reply #3 on: November 02, 2013, 10:10:20 pm »
I still am unable to get it to crash so if you would send me an example project I'd appreciate it.
daniel99
  • Me : Anim8or RULLZ \m/
« Reply #4 on: November 11, 2013, 03:12:06 am »
I had the same problem with some of my projects, in sequence or scene mode.
