General Category > Ongoing Anim8or Development
Changed to Older Releases [builds 1162 to 1230]
<< < (137/137)
Steve:
Sluggs: "... when I try to slice straight down from a point [with the knife], the cut is all over the place ..." I have a fix for this. To cut either horizontally or vertically, disable the Y/X axis. To cut at an arbitrary angle but without snapping to a point or edge, enable faces and disable points and edges. Will that work for what you need?
neirao:
--- Quote from: Steve on April 14, 2016, 05:19:03 pm ---neirao: Thanks for pointing this out. I normally use a large screen so I didn't notice it.
--- End quote ---
i load many icons plugins(for use or only for tests), this scroll help so much!
Sluggs:
--- Quote from: Steve on April 15, 2016, 01:16:19 am ---Sluggs: "... when I try to slice straight down from a point [with the knife], the cut is all over the place ..." I have a fix for this. To cut either horizontally or vertically, disable the Y/X axis. To cut at an arbitrary angle but without snapping to a point or edge, enable faces and disable points and edges. Will that work for what you need?
--- End quote ---
I was already doing that when I posted. :-) It's because of the picking distance. (When you start a cut near the point from which you want to cut, the cut starts from there, and even when you actually click on the point itself, not near it, it's not pixel perfect, so the cut is off)
Thanks for the other fixes though (undo, add edges, and the knot control handle). Now I don't have to keep switching versions.
Steve:
Sluggs: Sorry, my post wasn't very clear. I have a fix for the next build that will work. The current build still has the problem.
Sluggs:
Oh, I see! Well, shall look forward to it! :-)
Navigation
[0] Message Index
[*] Previous page
Go to full version
