General Category => Ongoing Anim8or Development => Topic started by: Steve on December 11, 2017, 11:33:54 pm
Title: v1.01 Development Release - Build 1357, March 15, 2019
Post by: Steve on December 11, 2017, 11:33:54 pm
The current development release is v1.01.1357, March 15, 2019: http://www.anim8or.com/download/preview/files/animcl1357.zip (http://www.anim8or.com/download/preview/files/animcl1357.zip)
These notes are for the development branch of Anim8or, currently labeled v1.01.xxxx. As changes are verified many but not all will be rolled int the main branch, v1.00x.
The following is a cumulative list of major changes to this development branch since the latest "official" release, v1.00b.
Major changes for build 1357 (http://www.anim8or.com/download/preview/files/animcl1357.zip) dated March 15, 2019:
ASL scanner: Add tokens for at sign "@" and questoin mark "?":
   ATSIGN_TOKEN
   QUESTION_TOKEN
Fix #101-028: Arc-Rotate Crashes in Perspective and Stereo Crash views.
Stereo Views: update in parallel when using Arc-Rotate.
Previous v1.01.xxxx releases:
Major changes for build 1356 (http://www.anim8or.com/download/preview/files/animcl1356.zip) dated March13, 2019:
ART rendering: Improve fast AA for transparent and reflective materials.
ASL scripts: Add "wb" option for ASL files.
ASL scripts: Save render images in script with new type image and output functions:
class image {
    int WriteBMP(string fName); // All functions return 1 if OK, 0 if failed
    int WriteJPG(string fName [ , int quality = 95 ] ); // 0 = lowest, 100 = highest
    int WritePNG(string fName [, int IncludeAlpha = 0 ] );
New member "GetImage()" in project type:
image GetImage(int image_id); // Returns NULL if no such image.
enum image_id { IMAGE_COLOR, IMAGE_ALPHA, IMAGE_DEPTH };
Fix #101-026: Sequences that go beyond the end of a scene don't extend the scene.
Fix #101-027: Stereo Crossed option doesn't do anything.
Stereo: Fix View->User and View->Stereo menu commands.
Stereo: Add menu option to swap left and right images for use in VR viewers.
Arc Rotate: When using Arc-Rotate in a camera or light view, alter the position and orientation of the camera or light accordingly.
Frames or Seconds: Add menu option to toggle between showing seconds or frame numbers in time tracks.
Major changes for build 1348 (http://www.anim8or.com/download/preview/files/animcl1348.zip) dated December 13, 2018:
Clay Model Style: Added a new rendering style for working views and renders that displays all objects using a two-sided clay material. This can make it easier to see the shape when you're modeling especially for objects with patterned materials.
Fix: Edit | Rotate doesn't work for components again.
Fix: Art FastAA crash when more than 256 samples are used.
Fix: GLSL fragment shaders: emissive weight was wrong, it used Ks instead of Ke.
Major changes for build 1345 (http://www.anim8or.com/download/preview/files/animcl1345.zip) dated December 2, 2018:
Reimplement: changes in builds 1325 to 1332 that were lost due to my disk crash.
Major changes for build 1332 (http://www.anim8or.com/download/preview/files/animcl1332.zip) dated August 6, 2018:
New Bone Editing Idea: This build has one major addition, an alternate way to edit a Figure's bone structure, plus a new way to show bones. Please post your comments about it in this topic (http://www.anim8or.com/smf/index.php/topic,5742.0.html).
Major changes for build 1330 (http://www.anim8or.com/download/preview/files/animcl1330.zip) dated July 22, 2018:
ART: Increase maximum number of threads for multi-threaded rendering from 8 to 16 (with an 16 core CPU).
ART: Add int attribute "MaxThreads" to set the maximum number of rendering threads.  0 = use Anim8or default. -N = use #cores - N.
Scene Editor: Add camera move/pan widget. Active in Arrow/Move and Arrow/Rotate modes.
ASL BUG: Restore LockAmbiantDiffuse, SetAmbientColor, SetDiffuseColor, etc. function calls that were accidentally deleted in earlier drop.
Fix bug from cl-1324: Edit->Rotate menu accidentally disabled in point editor when Delete Unreferenced Materials was added to Edit menu.
Fix #101-025: Image, Panoramic and Cube Map Backgrounds rendering issues.
Major changes for build 1329 (http://www.anim8or.com/download/preview/files/animcl1329.zip) dated July 7, 2018:
ART: Add multi-threaded rendering. Increases speed up rendering up to 8X (with an 8 core CPU).
ART: Improve Fast AA rendering speed and accuracy. (depth, light-mask, normals, materials)
Normal Maps: Fix problem in ART Normal Map rendering.
Normal Maps: Add new option to swap U coordinate direction.
Fix ART bug: where something marked Don't Cast Shadows do so anyway.
Fix #101-023: Ctrl-A Doesn't Select Faces in Groups.
Major changes for build 1325 (http://www.anim8or.com/download/preview/files/animcl1325.zip) dated May 30, 2018:
Delete Unreferenced Materials: new command.
Improve texture file searches: fix "./" file path bug.
ASL Materials: Add numerous new members, include two sided support. See the ASL spec (http://www.anim8or.com/scripts/spec/index.html#material_type) for details.
Major changes for build 1321 (http://www.anim8or.com/download/preview/files/animcl1321.zip) dated March 15, 2018:
Fix crash loading project introduced by cl-1320.
ASL Files: Add support for reading text files using GPScan token scanner. See this topic (http://www.anim8or.com/smf/index.php/topic,5705.0.html) for more details.
Major changes for build 1318 (http://www.anim8or.com/download/preview/files/animcl1318.zip) dated January 25, 2018:
Scene Editor: Added Element Folders which all you to group element in the track window for easier management of large projects.
- Fixed several minor Undo/Redo bugs such as Element name changes not being applied.
Major changes for build 1317 (http://www.anim8or.com/download/preview/files/animcl1317.zip) dated January 14, 2018:
Fix #101-017: Issues with Groups and Layers.
   Use group's layer instead of each component's layer when displaying or selecting a group.
   Use the group number of the components in a group when creating a group.
   For multiple group numbers, use any one of them.
Fix #101-018: Reading a .an8 file with a script-based parameteric shape in a group crashes.
Fix #101-019: Script controllers for scene morph targets with aren't saved in .an8 file.
IK effector: Change to not move location of effector unless the user have specifically moved it
(i.e. not when it was moved because it couldn't be reached when the whole figure was moved).
Connected Face Extrusion: Expand cases when new faces are kept parallel to original faces.
Inset Tool: Change to inset edges parallel and equal distance to original edges. Previous behavior (that moved edges relative to the length of each individual edge) is available using the Shift key.
Scene Editor: Add menu command Edit->Bones->KeySelectedControllers.
Fix #101-020: Object Editor: Copy/Pasting a Group with a sub Group doesn't work correctly.
Major changes for build 1314 (http://www.anim8or.com/download/preview/files/animcl1314.zip) dated December 20, 2017:
Depth Channel: You can now make movies of the depth channel.
Depth Channel: Fixed small bugs in Z-near/Z-far dialogs as they relate to rendering.
Frame Viewports: Hot-key f changed to frame only the focus view. Hot-key Ctrl-Sh-F added to frame all views.
User Lights: Added an option Options->UseDefaultLighting to disable user lights and use default lighting in the scene editor:
CAD: Display the angle between selected adjacent edges.
CAD: Highlight values in orange when the mouse moves over the component.
Material Samples: Fix bug where they didn't render when layer 0 was hidden.
Major changes for build 1312 (http://www.anim8or.com/download/preview/files/animcl1312.zip) dated December 11, 2017:
Fix #100-010:GLSL materials with more than 4 textures are broken.
Fix #100-011:Rendering a scene a second time hangs
Fix #100-012:Shape rotations don't follow object coordinates in object editor.
Fix #100-013:Object/Move command uses World coordinates when Object coordinates are selected.
Fix #100-014: Shell and Extrude Connected commands can cause spikes.
Fix #100-015: Sliding Resized Figures with IK.
Scene Editor: Add Copy/Paste for Scene Elements.
Object editor: Add Build->SplitSolids command that separates unconnected parts of a mesh or subdivision surface.
Pivot: Add Edit->Pivot->CenterPivot, AlignWithShape, AlignWithWorld commands.
Point Editor: Implement Edit->Rotate->Rotate commands.
Text Object: Add default font to project: type-face, size, italic, bold
Title: Re: v1.01 Development Release - Build 1312, December 11, 2017
Post by: fefe01 on December 12, 2017, 09:21:45 am
Wow, it is really great! Thank you very much Steve! Can the depth channel be enabled in the render movie menu in this version?
Post by: Steve on December 12, 2017, 04:50:45 pm
No, this build doesn't have an option for rendering a movie of the depth channel.
Post by: fefe01 on December 12, 2017, 07:08:28 pm
Anyway, all the new features are really satisfactory. Thank you very much Steve!
Post by: nemyax on December 14, 2017, 12:43:39 pm
This is a very welcome improvement, thanks!
I hope move and scale are coming soon, too.
Post by: Trevor on December 15, 2017, 03:19:01 pm
Ive been meaning to mention this since build 12xx but refrence images are not transparent in wireframe mode.
this means I have to switch to solid mode and assign a temporary transparent surface to model to match refrence image.
Trev
Title: Re: v1.01 Development Release - Build 1314, December 20, 2017
Post by: neirao on December 24, 2017, 11:35:39 pm
thanks!! Merry Christmas for All!!!
Title: Re: v1.01 Development Release - Build 1318, January 25, 2018
Post by: Steve on January 27, 2018, 12:24:47 am
OK one last post in the development branch: build 1318 (http://www.anim8or.com/download/preview/files/animcl1318.zip). If it checks out OK  I'll post a new v1.0 update.
The main change is that I added Element Folders which all you to group element in the track window for easier management of large projects. There is a new field in the Element Properties dialogs that let you specify a folder name. All elements with the same folder name [and parent element] are grouped under one expandable tree control in the Track Window.
This changed quite a bit of code, so please try it out and let me know if you find any issues.
Post by: Gyperboloid on January 27, 2018, 06:01:11 am
The current development release is v1.01.1318, January 25, 2018: http://www.anim8or.com/download/preview/files/animcl1318.zip (http://www.anim8or.com/download/preview/files/animcl1318.zip)
I don't know how I missed the 1317 release  :o , but that's superb Steve. Can the exact same behavior be implemented for the Bevel tool also ?
Post by: Steve on January 27, 2018, 05:56:13 pm
Yes, I'm working on Bevel but it's a LOT more difficult .... Stay tuned ....
Post by: chuft-captain on January 30, 2018, 05:13:57 am
Will check out this build as soon as I get a chance Steve, esp. as it looks like you may have addressed some of the issues I raised with you in December regarding Groups and Layers functionality.
(BTW. Does private messaging work on this forum? I sent you a follow up PM in Dec, but as there is no apparent Outbox/SentBox in the forum, in the absence of a reply from you, it's not clear to me whether PM's are delivered or not.)
CC
PS.
A suggestion for new functionality...
I do quite a lot of repetitive actions in my modelling (especially involving rotations, as I often design models which have some level of symmetry around the Y-axis).
For example, I might create a piece of geometry which I then want to duplicate and rotate through 60 degrees (x 5).
In this case the actions would be:
ctrl-V (Paste in the initial geometry)
then ...
ctrl-C, ctrl-V, Edit -> Rotate -> Rotate Custom -> tab to the Y-Axis box, type 60, click OK
and repeat this 4 more times...
WHat would be quite good is if there was some sort of "Repeat last operation" function (ideally linked to a hotkey ... perhaps ctrl-R or ctrl-shift-R)
This would significantly improve this workflow, by reducing the need to access several layers of menus multiple times in order to repeat the same rotation, and if tied to a hotkey would greatly reduce the tension in my mouse wrist!  8)
ie. It would be reduced to:
ctrl-C, ctrl-V, ctrl-R
I guess this "repeat last operation" could extend to other types of operations as well, not just rotations (that just happens to be the situation where I often find myself needing it).
Post by: selden on January 30, 2018, 12:45:15 pm
CC,
Groups can be used to reduce the number of manual copy-paste-and-rotate operations when the rotations are around a central point. You can group the models that already have been rotated and then rotate that entire group. It can significantly reduce the total number of operations involved. When you're done you can ungroup them all (or not) as appropriate. Similar groupings can help when creating linear assemblies.
I agree, though, that creating "macros" consisting of a sequence of operations would be very helpful.
Post by: Steve on January 30, 2018, 04:15:30 pm
chuft-captain: For your immediate example, try:
1.Copy, paste paste paste paste, and position them.
2.Select all copies and Edit->Rotate->Rotate Custom one time to rotate them all y+60.
In the past I've looked into building sort of "recorder" where you could record all actions and then play them back. Originally it was for making tutorials, but the underlying code could do what you suggest as well.
One big issue is that it has to work for pretty much everything. Partially working features are frustrating to use because sometimes they just mysteriously don't work. Another is screen resolution which affects some commands. And the big one is the amount of work to add it.
Post by: chuft-captain on February 01, 2018, 03:58:51 am
CC,
Thanks Selden,
I have in fact used that technique many times in the past which can be great for replicating geometry where symmetry is involved.
You may have misunderstood my description of the scenario. In my example, the first object is copied and pasted then rotated to 60 deg. It then has focus, so the next copy/paste operates on that object which is then rotated to 120 deg (60+60), the next 180, and so forth around the y-axis. --- So I end up with 6 objects at 0,60,120,180,240,300.
I should mention that these are imported objects which seem to be treated a little differently in rotation than natively created objects.
eg. If I draw a cube, position it at [-50,0,0] then rotate it, each copy is rotated about it's own internal axis.
(IMAGE1)
However, if I first export and re-import it (as an STL), then each copy is rotated about the workspace axis.
(IMAGE 2)
I'm NOT complaining! This difference (whether deliberate or not) is a very helpful feature, but anyway, the second scenario is what I was talking about, whereas I think you're talking about the first.
Quote from: Steve
I understand. It's just a suggestion for what might be a "nice to have", but the decision about what to do is entirely up to you, and must be tempered by the amount of work required, and the risk of regression/confusion.
My initial feeling was that this could be restricted to rotations, but I understand your motivation to implement a feature such as a "repeat last action/operation" with as wide a scope as possible.
I do think that cut and paste operations maybe should be excluded from a feature like this, and of course it should be subject to the usual undo/redo functionality.
If you were to add this in some form and extend it's use beyond just rotations, perhaps there still should be some limit to it's applicability ... ie. no cut/paste and perhaps limited to "transformation" type operations only, but then as you point out, you get into the issue of confusion around  "partially working features". I really don't have a broad enough knowledge of Anim8tor functionality to be able to suggest limits on it's scope.
Probably requires a bit more thought by "minds immeasurably superior to mine".... da .. da .. daaaah; da .. da .. daaaah !  ;-)
Post by: Steve on February 01, 2018, 06:15:59 pm
The reason that STL imports behave differently is that the format doesn't have a separate center (aka the "pivot") for the model, or for separate parts of the model, like Anim8or does. So Anim8or places the pivot at the origin.
Post by: chuft-captain on February 02, 2018, 12:30:17 am
Thought that would be the reason ... and it's a good thing, because often it's very helpful to rotate about the origin instead of the mesh's pivot ... and you know what I'm going to say next don't you ...   ;D 8) ... that it would be a good option to offer users when doing rotations of native meshes .. the option to rotate around the origin instead of the mesh center.
Post by: Claude on February 02, 2018, 03:04:44 am
In axis mode,you can move and rotate the pivot point.
Post by: chuft-captain on February 02, 2018, 03:20:06 am
Claude,
That's good to know ... but to borrow a phrase by Slartibartfast from Hitchhiker's Guide, "I don't know this 'Axis' mode of which you speak".
The only "modes" I have ever seen are Object, Figure, Sequence, Scene.
(I did say my knowledge of Anim8or features was not that broad, didn't I?  8) :D :D ::) )
Thanks!
Post by: Claude on February 02, 2018, 03:54:53 am
This button called Object/Axis mode lets you move an object's pivot or origin.
http://www.anim8or.com/learn/manual/buttons/b_axis_s.png
There's also some special functions in menu Edit/Pivot.
Sorry if my answer lacked details.
Post by: chuft-captain on February 02, 2018, 04:38:05 am
Claude,
I can't find that button in my version (latest dev build 1318).
The only button that looks vaguely like it is in the Coord section (group of three) but when I hover over it, it says "World Coordinates <w>".
Is that the button you meant?
EDIT: Forget that, I think I just found the button you mean (just above the other one) ... sorry about that. I'll try that out to see it's effects.
Post by: chuft-captain on February 02, 2018, 05:08:59 am
No need to apologize,
Tried that out, and it seems to do pretty much what I was suggesting to Steve, so it looks like he has already long ago implemented this, just in a form which I was unaware of.
(There are large sections of Anim8or functionality that I have barely touched on, so please excuse my ignorance.)
Thanks for the guidance. I learn something new about Anim8or every day, and it just keeps getting better and better!
Post by: chuft-captain on February 02, 2018, 05:26:21 am
Steve,
Sorry, I appear to have hijacked this thread a bit. If you want to keep this thread on topic, you can split off all my suggestions into a separate thread if you like (especially as it turns out you've already implemented most of my suggestions in some form or other a long time ago!)
CC
Post by: chuft-captain on February 02, 2018, 10:03:22 am
Steve,
I just did a very quick check of the Group/Layer changes, and on first glance it looks great!
Individual and combinations of layers can now be displayed or hidden at will, regardless of the status of Layer 0, and it appears that Layer 0 is no longer treated as a special case. (This I agree with completely.)
I'm sorry, I don't have time to test these changes in depth at the moment, but on a very cursory first glance it looks really good, and I'm amazed you got this done in such a short time since Christmas! Thanks a lot!
I'll do some more in-depth testing of the interaction between Group/Ungroup actions and layer memberships when I have more time, but it's looking good so far.
CC
Post by: itsstillthinking on March 26, 2018, 04:26:57 am
Was wondering if i could maybe add something for the next build? Something i always wanted was that when one is animating a object if one wants to move a object a short distance over a small length of time it will always make a "Hairpin" curve on the track that the object will follow. This can be annoying when animating objects as you have to manually find what the center of the object is so you can move it back to a strait line. Be great it it did not automatically do that! 8)
Post by: AlecJames on March 26, 2018, 08:26:22 am
I think Anim8or can already do what you want.  A key can be step, corner or smooth.
This next bit I need others to confirm - when a key is corner or step, it allows you to change the path in the graph editor, so with a corner key you can create literally a corner on the path but you have to make the corner in the graph editor. Simply changing the key type is not enough.
I've never got on well with graph editor, I'm going to spend some time with the manual later to try to understand why the UI does not always behave as I expect.
(Sometimes I cannot select a key to get the handles to appear - not sure why)
Post by: itsstillthinking on March 26, 2018, 03:21:21 pm
Thanks everyone, il give it a try as soon as i can! Sorry everyone for all the questions :P
Post by: itsstillthinking on March 29, 2018, 03:02:58 am
Been playing around with it and sadly it seems that using the graph editor cant really fix the problem :'(
Post by: AlecJames on March 29, 2018, 07:38:33 am
Can you post an example an8 file with the problem?  e.g. A single sphere in a scene with the "hairpin" you refer to?
Post by: itsstillthinking on March 30, 2018, 12:16:34 am
Quickly threw together a example
Post by: AlecJames on March 30, 2018, 12:28:52 pm
Moved keys discussion to "General anim8or forum" http://www.anim8or.com/smf/index.php/topic,5712.0.html (http://www.anim8or.com/smf/index.php/topic,5712.0.html)
Post by: polyGon_tError on May 27, 2018, 05:11:46 pm
hello Steve, i have some issue esp. with bump tool top faces of bump area is missing when using that tool but it is showing when other option is selected, strange ...
* can you please implement group inset? :)
Post by: Steve on May 27, 2018, 07:07:28 pm
polyGon_tError: There is a problem with the material for selected faces in the bump tool and a few others. They either aren't shown or are drawn with 100% transparency, I can't figure out which. So far I haven't been able to find the problem. It only happens with the new OpenGL faster rendering is enabled (Options->Debug->NewOGLRenderer).
What do you mean by "group inset"?
Post by: polyGon_tError on May 27, 2018, 08:53:10 pm
this option, actually close to bump but instead raising and spreading selected face group (connected) border toward face average normal distribution (in and out) it inset selected face group(connected), bump tool is useful and i use it to do like this ... i was implementing one in script but long time passed and you made lots of changes, so asking here instead :)
* can you please provide me a list of what changes you made to ASL after version 0.98 esp. if any of this get changed http://www.anim8or.com/smf/index.php/topic,4634.msg33287.html please write there other will also learn ...
Title: Re: v1.01 Development Release - Build 1329, July 7, 2018
Post by: neirao on July 09, 2018, 10:19:00 pm
Thanks Steve!!!!!!
Post by: Kyle on July 14, 2018, 01:22:19 am
Oh cool, this update should mean I can have windows (with transparent properties) set to not cast shadows while still using art. I had to omit the glass before to use art.
Edit: camera movement using the old arc rotate shows erratic behavior when middle mouse clicking.
Edit 2: can you elaborate on what this is about steve?
Title: Re: v1.01 Development Release - Build 1330, July 22, 2018
Post by: neirao on July 28, 2018, 01:02:32 pm
Wooww!
Very Nice the 'camera move/pan widget. Active in Arrow/Move and Arrow/Rotate modes'!
Thanks!!!
Post by: Steve on July 28, 2018, 04:23:29 pm
neirao: the ner camera controls make it much easier to smoothly dolly and pan the camera. I still have a bit of work to do to eliminate the over/under shoot of the movement. Currently you sometimes need to fix that in the graph editor, but I think I have a solution.
Title: Re: v1.01 Development Release - Build 1332, August 6, 2018
Post by: scoop7 on August 16, 2018, 01:19:44 am
Build 1332 has been very helpful for me...an alternate way to edit a Figure's bone structure, plus a new way to show bones, has been just awesome.
I was wondering if when entering Figure Mode if the ball showing in the center could be preselected,so that you do not have to select it to than add a bone.
Just trying to cut down on moving mouse back and forth to select.....just a thought....LOVIN ANIM8OR
Post by: AlecJames on August 17, 2018, 08:15:18 pm
Welcome to the forum scoop7
Sounds like a simple enhancement but I think Steve is busy refactoring some of the recent updates :)
Post by: Steve on August 19, 2018, 06:39:22 pm
scoop7: if you Fast Select (hot key Ctrl-T) is enabled you should be able to click-drag on the root bone and it will be selected automatically.
Post by: Michel Colašo on September 06, 2018, 05:20:07 pm
Congratulations Steve! The new updates worked very well for me! especially copy and paste object within the scene and the new editor of bones. Steve, do you think it would be possible to edit wireframe points within the scene mode? I use a lot of morph, but I think this could speed up a lot of processes!
Post by: Trevor on September 12, 2018, 06:22:29 pm
steve, can you fix the "Backfaces" button/preference so that it actually culls backfaces. As far as I know its never worked but it would be handy if it did :)
Trev
Post by: Steve on September 13, 2018, 08:42:11 am
Michel Colašo: I can see how editing morph targets in thescene editor would be helpful. Anim8or isn't quite set up for that but I'l see if I can figure out something.
Trevor: Those buttons should disable the selection of front or back faced polygons, edges and points.
Post by: Trevor on September 15, 2018, 10:10:31 am
sorry steve, I don't mean the left hand toolbar, I mean in "Options > [ ]Backside" and "View > Preferences > [ ]Backside"
Disabling these makes no difference in the viewport.
Trev
Post by: Steve on September 15, 2018, 03:17:15 pm
OK that was used by the origional Anim8or software renderer. Not everyone had working OpenGL drivers in the early days so I added a software path for drawing the working screens. Disabling backfaces often made it run much faster.
How important is it? At first pass it seems that it would be easy to add, but I suspect that a lot of things won't work correctly without a tom of tweaking.
Post by: Trevor on September 16, 2018, 04:58:49 pm
Its not HUGLY important, but does come in usefull from time to time when modeling inside a box.
At present I use the double-sided material with back set to 0 for transparency BUT if 2 such surfaces overlap then both become transparent (even if facing front) so it doesn't work all the time.
Culling backfaces directly with a toggle switch would be more convenient and should not incur such a bug as the material method.
Trev
Post by: daniel99 on October 06, 2018, 05:58:50 am
Hey, @Steve
       Just a quick question. Let's say I have Scene01, with Figure01 (animated). If I create Scene02, I import the same figure, and I try to copy the animation keys it won't work. Also, the lights or camera animations keys from one scene to another. Will you consider that, would be very helpful.
       Second. Is there a way to only render the shadow cast by a figure/object? That would also be amazing, being helpful in compositing.
       How it would be to use hrdi or panoramas to light a scene or character?
Thanks.
Post by: Steve on December 04, 2018, 01:49:10 am
OK I think I have rewritten everything that was lost when my disk crashed. It's Build 1345 (http://www.anim8or.com/download/preview/files/animcl1345.zip). Let me know if I missed anything.
Post by: nemyax on December 04, 2018, 09:06:37 am
Post by: AlecJames on December 04, 2018, 04:23:07 pm
Thanks Steve! :)
Post by: Steve on December 04, 2018, 10:39:56 pm
nemyax - "Edit | Rotate doesn't work for components again."
Thanks, I'll fix it.
Post by: nemyax on December 05, 2018, 02:29:23 pm
Cool! Can you also add Edit | Scale and Edit | Locate capabilities for components?
Post by: Trevor on December 07, 2018, 04:22:19 pm
Oh wow, the re-write also seems to have fixed "bright internal corners" bug.
This is what it looked like before (1332)
(http://www.anim8or.com/smf/index.php?action=dlattach;topic=5667.0;attach=15082;image)
this is 1345
(http://www.anim8or.com/smf/index.php?action=dlattach;topic=5667.0;attach=15080;image)
Thanks steve,
Trev
Post by: Steve on December 07, 2018, 07:29:25 pm
Trevor: Cool! I'm glad it's fixed. I'm not exactly sure what fixed it, but I've made a number of small changes for other bug.
I'm curious, so I'll check older builds to see if I can find the fix :)
Post by: neirao on December 20, 2018, 09:47:17 pm
tested!
very satisfying modeling on Clay mode! :)
Thanks Steve!
Title: Texture differences between 1345 and 1348/ Scene Mode Camera selection
Post by: dancingshoes on January 11, 2019, 12:11:19 pm
I noticed that in scene mode selecting the camera view via the menu (View->other->camera01) is not the same as selecting the 'Camera' via Num-1. 'Camera' does not equal 'Camera01'. Transparency is handled differently between the two(?). 1348 doesn't allow you to select 'Camera', via the menu and 'Camera' seems to handle things properly.
And compared to 1345 (and earlier) and 1348, I'm getting different handling of textures in the display. One example, among several, is attached.
Is this because of the shader fix in 1348?
Otherwise 1348 looks good!
Post by: Steve on January 11, 2019, 05:47:23 pm
The ''Camera" view is the active camera. It behaves differently from "normal" views in ways like not showing lights or other cameras.
Individual camera views are the view for that camera. The behave like all the other views, showing lights etc. This allows you to position lights and such easier.
I'll look into the texture issue and get back to you. Also transparency for camera views.
Post by: dancingshoes on January 11, 2019, 06:17:27 pm
Thanks for the responce.
Looking further, my difference between 'camera' and an other-> 'camera01' seems to be at least that 'camera' responds to enviromental fog whereas an other->camera01 does not.
True back to at least 1269.
Thanks.
Post by: captaindrewi on January 20, 2019, 12:40:58 am
@Steve ..Where has the alternating between point, face, edge, expansion of selected area function gone? I really liked that.Hope it's coming back in some form.
Post by: Steve on January 20, 2019, 03:47:20 pm
You can set Anim8or to expand the selection or not with the "Extend Point Edge Face Selection" check box in the File->ConfigureUI dialog.
Post by: captaindrewi on January 20, 2019, 07:23:33 pm
Phew!.. :)Thanks
Post by: captaindrewi on January 22, 2019, 02:58:09 am
I am not seeing the background image in scene mode.1348 1349.
Ah! i see reading 'Dancing shoes' post this issue has been already highlighted.
The usual camera selection has gone from the view menu so i used the wrong camera selection.
Post by: bayinghound on February 05, 2019, 12:21:07 pm
Having a little issue with setting up a scene on the most recent build from December 2018. when I attempt to do a background, either images or color, it doesn't show using the active camera or during render. Am I missing something or is this a bug?
Post by: bayinghound on February 05, 2019, 12:38:40 pm
Scratch that. Read the "Dancingshoes" post. Showed up in render after I renamed "camera01" to "camera."
Title: Re: v1.01 Development Release - v1.01.1348, December 13, 2018
Post by: slex on February 09, 2019, 02:06:25 am
"Stereo view" is not shown in context menu in scene mode- on the top of the screen. It's still remains in upper left side of he work space menu, and it works fine. I just hope that it doesn't get removed in future builds, it's a nice feature.
Post by: Steve on February 09, 2019, 09:16:14 am
Oops! Didn't mean to remove stereo from the menu. I'll fix it.
Post by: Trevor on February 09, 2019, 09:13:52 pm
can you add "fixate" to stereo view so that both sides move when moving either the camera or alt - last time I checked only one side moves which breaks the stereo vision without reselecting the view from menu.
also can you add "swap eyes" to enable cross-eye or vr viewing.
actually, on the subject of vr, you wouldn't be able to add full screen workspace and custom ratio to stereo too? what I mean is, with the Oculus I was able to use a desktop VR app that literally splits the screen down the middle for left and right however it kept the original desktop ratio so the image appears stretched.
thanks
trev
Post by: bayinghound on February 25, 2019, 12:45:36 pm
Having some issues with scenes. I played around with the suggestion from Dancing Shoes but a few things I've come across:
I changed camera01 to camera as suggested. Works fine if you just use a color as a background, but won't work with a background image.
Lights show up during rendering.
Post by: bayinghound on February 25, 2019, 02:06:25 pm
One other thing, texture transparencies are fine in object, figure and sequence, and scene, but totally ignored when you render.
Post by: Steve on February 25, 2019, 06:19:22 pm
Only the active camera view shows the background and automatically hides lights and other cameras. This makes it easier to positioned cameras relative to the other cameras and lighting elements.
Post by: bayinghound on February 27, 2019, 09:27:28 am
The camera is marked active. I only have one camera in the scene. I've tried renaming the camera but that doesn't work either. It totally ignores any background image, solid colors, no problem. Still seeing the lights as well. Am I doing something wrong?
Post by: bayinghound on February 27, 2019, 01:31:04 pm
Perhaps I should illustrate
Post by: Steve on February 27, 2019, 05:00:15 pm
There is a built-in view named "Camera" which shows the active camera, whichever on it may be. To see this view, use the menu command View->Camera,, type Num-1 on the numeric keypad, or use the on screen drop-down menu to select Camera. This is the only view that shows the background and hides lights, etc.
The other camera views can be seen through View->Other->Camera01 (or whatever is the camera's name). This view does not show the background and does not automatically hide lights, etc.
If you rename "camera01" to "Camera" it will only cause confusion so it's best to leave it as "camera01" or use some other useful name such as "POV camera", "wide-view", etc.
Post by: AlecJames on February 27, 2019, 05:33:33 pm
Is this problem related to "camera" being missing from the View menu in 1348?
You have to use Numpad-1 to switch to the required camera view to render and there is no hint, you need to know from previous versions.
And (I think) that if you are in 2 views (etc) you have to use View-->Front then Numpad-1 to get back to a single view camera because Numpad-1 in 2 views etc changes one of the 2 views.
I think Steve commented on a thread somewhere that camera is going back on the view menu in a future release?  Or is it done already and I'm on an old version?
Post by: Steve on February 27, 2019, 07:08:58 pm
Dropping the camera from the View command was a bug. It'll be fixed in the next drop, probably next week if not earlier.
Post by: bayinghound on February 27, 2019, 07:36:59 pm
I should have clarified the version. Using 1348.
I absolutely love anim8or even if I don't know what I'm doing half of the time. :)
And thanks Steve, for your quick reply.
Title: Re: v1.01 Development Release - Build 1356, March 13, 2019
Post by: Steve on March 13, 2019, 09:23:26 pm
I just posted build 1356 (http://www.anim8or.com/download/preview/files/animcl1356.zip) with some new features. See the top of this topic for details.
Post by: nemyax on March 14, 2019, 11:31:07 am
Classic arc rotate is broken in perspective view.
Post by: Steve on March 14, 2019, 04:37:54 pm
Oops! You're right - Perspective and Stereo views crash when using arc-rotate. I'll fix it :(
#101-028 - Arc-Rotate Crashes in Perspective and Stereo Crash views.
Post by: Steve on March 15, 2019, 11:04:49 pm
Crashes should be fixed in build 1357 (http://www.anim8or.com/download/preview/files/animcl1357.zip). Also when you use Arc-Rotate in a stereo view it moves both eyes at the same time (http://www.anim8or.com/em/johnar/smile.gif)
Title: Re: v1.01 Development Release - Build 1357, March 15, 2019
Post by: chuft-captain on March 15, 2019, 11:06:41 pm
Steve,
Just wondering if you also had a fix for the frustrum issue ( culling ? ) I raised with you around Sep/Oct just before your Italy trip.
Sorry to harp on about this, but I checked the last DEV build 1348 (December) and it had not been fixed at that point. Let me know if you'd like me to re-send you details if you've forgotten or overlooked this.
Regards
CC
Post by: Steve on March 15, 2019, 11:21:14 pm
Unfortunately I haven't been able to find the cause of this yet. I'll give it another look.
