May 23, 2013, 08:44:12 pm *
Welcome, Guest. Please login or register.
Did you miss your activation email?
News: The v0.97d Preview is now available!  See the "Anim8or v0.97 Preview" Forum for details.
   Home   Help Search Login Register
Pages: 1 2 [3]
  Print
Author Topic: Kubajzz's toolbox  (Read 15487 times)
Flying Platypus
Global Moderator
Sr. Member
Little doggie ate my avatar...
View Profile
« Reply #30 on: October 21, 2008, 03:21:27 am »
Yes, I've read you laptop works now... Congratulations!
Quote from: headwax
I am even able to spell your name now Smiley
haha, you're a genius!!!
Global Moderator
Hero Member
View Profile WWW
« Reply #31 on: October 22, 2008, 11:08:08 am »
Many Thanks Kubbajzz
Now I can get anim8or to run on my laptop I will be abnle to try them out. The join two points and cut face tool looks very handy.
This last one will be great for morphs - and go nicely with morph envy.
cheers and thanjks again
Hahah, it seems that you still spelled it wrong (it's with 1 'b'  Grin).
Great script kubajzz, (<-- like that headwax  Wink) great to 'dirt-up' models like stones or other models that need to look like they had a beating  Cheesy. many thanks
almost cool
Sr. Member
The Truffle Shuffle
View Profile WWW
« Reply #32 on: October 27, 2008, 01:10:53 pm »
Well it was handy for my earthen tunnel.Also for abstract work.
Francesco
Full Member
View Profile
« Reply #33 on: November 01, 2008, 06:17:04 pm »
Just downloaded the whole package, I seriously need it if I want to use Anim8or at best, this stuff is a must.
3Dgeek11
Sr. Member
Roll Tide.
View Profile WWW
« Reply #34 on: November 04, 2008, 02:44:44 am »
Here's a suggestion. How about Steve putting a bundle of all the "must have"s scripts? And putting it on the main site? And updating it regularly every release of course.
I just downloaded all of them, Kubajzz! They look awesome!!!!! Cheesy (I don't normally use that many smilies, but in this case, it's needed! Cheesy )
Keep it up!
Global Moderator
Hero Member
View Profile WWW
« Reply #35 on: November 04, 2008, 06:06:30 am »
Keep it up!
Good idea, the scriptpage really needs to be update. There so much scripts that are helpfull.
Here is a .zip files with all my scripts, might be helpfull to people who don't have them. Have fun!
Flying Platypus
Global Moderator
Sr. Member
View Profile
« Reply #36 on: November 09, 2008, 07:25:57 am »
Yay, thanks guys Smiley I appreciate your feedback.
Here is one more plugin, this time it's something for all those game-makers in the Anim8or community: poly-reducer plugin.
Select one triangulated mesh and run the script. As far as I know triangulated meshes are usually used in the 3D-games industry, but you may need the Triangulation plugin by Claude and Un-triangulation plugin by NickE.
Create an attribute called "reducer" to specify the amount of reduction in percent. The default value is 25, you can enter anything between 1 (slight reduction) and 95 (maximum reduction).
Although I tried hard to optimize the algorithm, this script works very slow, it takes about 5-10 minutes to reduce a 1000 poly mesh... If you work with very complex models (3000+ polys), the script execution will probably take too long and I recommend using an external tool. You can abort the script during the execution by creating an attribute called "stop".
The script saves the materials and UV coordinates, but you'll probably have to redo the texturing anyway since the script changes the whole structure of your mesh.
Ok, that's all you need to know Smiley The script file and demo image are attached below.
« Last Edit: December 15, 2008, 11:32:28 am by Kubajzz » Logged
Flying Platypus
Global Moderator
Sr. Member
View Profile
« Reply #37 on: December 15, 2008, 11:33:37 am »
I updated my post above with a new version of the PolyReducer plugin, it now keeps the materials and UV coords.
Full Member
View Profile WWW
« Reply #38 on: November 17, 2011, 08:14:35 am »
hi kubjazz
i really love this script and find it massively useful but often i want it to stop before it ends because with a complex mesh it goes on for rather lengthy times beyond where i would like the mesh to go.
it would be useful at times to just have miniscule distortions.
 is there a way it could be stopped by pressing a key?
sorry forgot to mention i'm referring to the 'deform' script Smiley
« Last Edit: November 18, 2011, 07:27:07 am by captaindrewi » Logged
ANIM8OR...double click!
Arik_the_Red
Sr. Member
Just another aninoob...
View Profile WWW
« Reply #39 on: December 23, 2011, 10:26:30 pm »
Does anyone know what became of Kubajzz? Hasn't logged in for nearly a year Sad
Sr. Member
View Profile
« Reply #40 on: December 24, 2011, 02:41:41 am »
I think he's just busy snowboarding at the moment Smiley no worries! I'm sure he'll be back sometimes..
Full Member
View Profile WWW
« Reply #41 on: December 24, 2011, 12:15:34 pm »
i may have even asked this question before re deform script..as i have just realised there are attributes that can be adjusted.....i seem to have a feint memory of this now.
though a problem seems to exist when you attempt a sub division of the deformed mesh..again i think i may have encountered this problem before and found a solution but cant remember what...possibly by saving and re importing.
Pages: 1 2 [3]
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
