Pages: 1 ... 4 5 [6]
Author Topic: ASL Scripts Database  (Read 113905 times)
Re: ASL Scripts Database
« Reply #75 on: February 11, 2014, 01:57:51 am »
Sorry, seems my webhost is slackin'. Working on it.
[edit]I should mention that the related links under nearly every script should still work, for the most part.
« Last Edit: February 11, 2014, 02:28:16 am by Raxx »
GATTISNEW
« Reply #76 on: August 10, 2014, 12:10:09 pm »
The link for the ring script  is broken :'(
« Reply #77 on: August 12, 2014, 04:06:09 pm »
If any of the links are down, send me a message. I had to reboot the server, should be A-okay now.
kakachiex
« Reply #78 on: October 22, 2014, 03:38:56 pm »
hello Raxx would be nice to have scrip pack download link, like modeling pack, shape, render etc... it is weird to download all individual would be good to have this option over every category.
polyGon_tError
« Reply #79 on: March 13, 2015, 03:41:08 pm »
Hello Raxx,
why don't you add my modeling tool set here or atleast mention it here, though some of them get replaced by new function of anim8or and i am happy with that but what about other?
  • Neirao
Plane Stand-up : Plugin
« Reply #80 on: March 14, 2015, 07:03:19 pm »
hi guys
years ago i change the "Plane Primitive Plug-in / Tyson Collins"
and create this simple plugin:
Tela(screen) is a "Plane Stand-up!"
only now i remember to share :)
is simple but for me is very helpfull!
« Last Edit: March 14, 2015, 07:08:59 pm by neirao »
« Reply #81 on: March 17, 2015, 08:54:41 pm »
Hello Raxx,
I won't add anyone's scripts to the list, there's a character limit to how much you can put in one post and I've already reached it. I intend to put everything on An8Hub when it's complete, and then simply link to that website since it'll have a much more sophisticated library of resources. It's not just you I'm ignoring. I haven't updated the list in more than two years.
That being said, please continue to post your scripts as replies to this topic or in their own topics in this board, so that I can publish them on An8Hub when it's time.
Thank you.
texastuner
« Reply #82 on: May 16, 2017, 09:08:52 pm »
How would one write a controller script that would randomly position an object (x,y,and or z) per frame. Have tried for 2 days and got nowhere but a lot of crashing. If not proper forum please direct me to proper forum
« Reply #83 on: May 17, 2017, 12:48:20 am »
Use the randseed() and frand() functions in a position controller script. The random number generator always starts with the same random when a script is run. This insures repeatability. Otherwise each time the same frame was drawn it would be different.
// Set position to a random position based on frame number.
float $x, $y, $z;
randseed(frame);
$x = frand()*100.0;
$y = frand()*50.0 + 50.0;
$z = frand()*100.0;
$position = ($x, $y, $z);
So in this script I initialize the pseudo-random number generator with the frame number as it's seed. Then I call it 3 times for each if the x, y and z components of it's location, and scale them to make the object jump about quite radically.
I've also attached a simple project.
texastuner
« Reply #84 on: May 17, 2017, 10:01:47 pm »
WOW talkin about a duh moment times 2 days. How did i forget randseed. Again Steve u r awesome bro thx for all your hard work and help
Punth
« Reply #85 on: January 11, 2019, 08:31:34 pm »
Most scripts in many links do not work now. Could any one update them to Google Drive and share them, please?
I would like to get this two scripts as follows. Also it is possible that F8ce can be updated as a new version as possible.
Boolean Operations
Create a wide variety of shapes easily using this plugin! Enables union, intersection and subtraction.
Author: Kubajzz with the help of NickE
F8ce
An an8 version of MakeHuman, allowing you to easily create a variety of humanoid characters.
Author: Bob_I_Ts
« Reply #86 on: January 12, 2019, 11:14:32 pm »
@Punth I'm consolidating my domains and hosting. The links should now work.
