Author Topic: HELP in Script (tree script)  (Read 5524 times)
  • Neirao
« on: May 22, 2009, 01:46:48 am »
Hi guys,
please someone can help me in this script..?
is a simples script based in hair script, it make one pseudo tree, but can be used to maker grass, fur, etc, if changer the textures..
..i think then need change/insert the SIMPLE LINE CODE.. but im not  good
in ASL scripts..(STILL)  :'(
the script files are be attached(zipped) below
thanks so much all!!  :)
« Last Edit: May 22, 2009, 01:52:57 am by neirao »
Re: HELP in Script (tree script)
« Reply #1 on: May 22, 2009, 04:25:54 am »
I  had a quick look.
Here's a few suggestions:
The code to create the material should be moved right after the
$currentMaterial = $curObject.LookupMaterial("arvore_textura");
line so that you have your material ready
when you create your plane.
After the line
$plane.Open();
you need to use this function to add the material to the plane
int AddMaterial(material mat);
AddMaterial() adds a  new material to the Mesh and returns its index.
Index you need next.
The first parameter of the OpenFace function is the material index
assigned to the face
$plane.OpenFace(0,4);
Good luck
  • Neirao
« Reply #2 on: May 22, 2009, 01:33:02 pm »
Claude thanks for hint, :)
but i not have succeed... :(
i not very good in ASL..
other someone can help me ??
thanks!
« Reply #3 on: May 22, 2009, 06:10:57 pm »
I implemented my suggestions.
Here's the result.
  • Neirao
« Reply #4 on: May 22, 2009, 10:17:06 pm »
VERY THANKS Claude!!!!! :D :D :D
the script Work!! You are a Genius!! ;)
now i can maker previous textures,
to maker some effects!!
thanks again!
dajean
  • Creativity
« Reply #5 on: June 03, 2009, 02:17:21 pm »
really nice script, thanks guys.
