Author Topic: how do i make the .a8s extension???  (Read 3320 times)
margo308
« on: July 12, 2009, 06:13:15 am »
i have bin here lookign geting frustrated and i still can tget my scritp to have the extension(i am making ym scripts in notepad using vista) ???
margo308
Re: how do i make the .a8s extension???
« Reply #1 on: July 12, 2009, 06:14:47 am »
like am i using the wrong spit to make scripts or what?
Jdez
    • Tech Blog
« Reply #2 on: July 12, 2009, 06:54:01 am »
As far as I know you should be able to save your .txt from notepad as a .a8s all you have to do is when you are in the save dialog you must select all file types then at the end of the name of your file you must write .a8s. for example I create a script and I go to save it I select All files in the file types then I write in the file name script.a8s
Hope that helps
Having fun with ASL!
margo308
« Reply #3 on: July 12, 2009, 07:15:08 am »
hope i does to ty
Monex
    • My homepage (not done)
« Reply #4 on: July 12, 2009, 10:44:05 am »
If you set "Hide extensions for known file types" to unchecked -> http://windowshelp.microsoft.com/Windows/en-US/help/a0b4607a-6fa8-42ab-aef6-7418183389da1033.mspx then you can see the extension ".txt" and change it to ".a8s".
