Author Topic: I'm New to Anim8or  (Read 2554 times)
Giggy9200
I'm New to Anim8or
« on: August 11, 2009, 05:34:50 pm »
I'm new on Anim8or and am still learning, has anyone got any ideas which are easy things to start on? Also how would you go about getting a headband on a head?
Thanks
Re: I'm New to Anim8or
« Reply #1 on: August 11, 2009, 05:36:51 pm »
When you start out it's helpful to read the manual and do some of the tutorials. You can find those with the links on the left (<--).
Giggy9200
« Reply #2 on: August 11, 2009, 05:47:08 pm »
Thanks, I have tried some of the tutorials but I may as well do some more!!
Pincho
« Reply #3 on: August 12, 2009, 07:42:28 am »
A headband is a cylinder with a hole cut out of the middle, the splines added around the inside hole, and then the hole filled again, but with the splines added you end up with a head band.
xfx
« Reply #4 on: August 12, 2009, 11:40:23 am »
headband try  = build = primitive = nongon 33 = ok
then draw a rough rectangle = extrude = path = ok then click on circle and bang done
rellik420
    • youtube channel
« Reply #5 on: August 12, 2009, 01:24:21 pm »
another way to make a headband (if you already have a head) is to
copy your model
hide your original model
paste your model
delete all the edgepoints except where you are going to put your headband (on your copied model)
make your headband (it could be as simple as extruding the faces)
once your headband is done unhide your model
then join solids
then merge the points
done (perfect fit)
ive dont that "method" a few times when making accessories and hair and stuff. it works pretty well.
h
Pincho
« Reply #6 on: August 12, 2009, 04:04:34 pm »
copy your model
paste your model
then join solids
done (perfect fit)
Yeah, and you could also use the cut tool on the head if you don't have faces in the right places.
B3dman
« Reply #7 on: August 15, 2009, 04:52:43 am »
an easy way to do a good headband is to make the head have 2 little "thingies" off of the back like the ends of the knot and then just have the texture on the head look like whatever headband you might want to use.
Galatians 5:6
