Author Topic: How do you make a realistic rain scene?  (Read 7614 times)
RnDr FOX
  • Just Relax
« on: February 21, 2008, 02:30:46 am »
I was wondering how do you make a realistic rain sequence? What should the object look like and list everything please.
im not a people person73
  • P.I.E
    • my NG
Re: How do you make a realistic rain scene?
« Reply #1 on: February 21, 2008, 02:36:44 am »
i'd still call myself a newb,but i'v been using anim8or for a while, so please correct me if i'm wrong and anim8or can't do this (i dont consult the manual much).an animated rain sequence in the background(if it can be used).
Gween123 is also me (NEWGROUNDS)
lynn22
    • 3D Animation
« Reply #2 on: February 21, 2008, 07:32:59 am »
If you get Terranim8or v6.6.1, that will create rain for you and insert it into your Anim8or project.
http://www.biederman.net/leslie/terranim8or/terranim8or.htm
machineman9
« Reply #3 on: February 24, 2008, 08:04:42 pm »
Definately Terranim8or.
Look in the Movies section on anim8or.com and check the crazy trousers video
Youtube is down so I cant send a link, but it is on there too.. very good video to see the rain in action and also good for learning about how to do more complex things (the flying paper is really good, gives it a nice feel of physics- as with the bollard)
My computer specs:
1.8Ghz dual core (Intel 6320) processor
2Gb RAM
Win Vista Home Premium
512mb 8600GTS graphics card (slight O/C)
saakhmet
    • kaddiska's space
« Reply #4 on: February 25, 2008, 03:14:08 pm »
ok..like how do i also make realistic rain with terranim8or version 7.0 ?
Leslie
« Reply #5 on: February 25, 2008, 08:22:59 pm »
Terranim8or v7 does not make rain. Only v6 has that feature.
« Reply #6 on: March 02, 2008, 12:38:41 pm »
T v.7 also has rain you only need the plugin for it which can be found at the terranim8or site.
Leslie
« Reply #7 on: March 02, 2008, 08:25:47 pm »
Thanks, floyd86, of course, but before that, someone should write that plugin! Would you have a try at it? :)
« Reply #8 on: March 03, 2008, 10:49:38 am »
Isnt there a plugin yet then? I thought i downloaded one last week? Probably i was mistaken then, sorry =(. I cant wright scripts at all so thats not an option either. I think your should stick to T v.6 then.
B3dman
« Reply #9 on: March 05, 2008, 12:12:50 am »
try doing the low poly way by:
1. make a cylinder and rotate it 90 degrees in the Z axis(right mouse button)
2. apply your rain texture and click the UV button
3. make the texture look as small as you can
4. in scene mode put the cylinder into the very back and scale it till it covers the background
5. during animation rotate the cylinder throughout to make the drops "recycle"
ps  i have not tried this but in theory it should work anyone let me know how it works for them
Galatians 5:6
  • P.I.E
    • my NG
« Reply #10 on: March 05, 2008, 12:47:09 am »
that sounds really logical and awsome! but what if you want it to envelope around the character? let me reword that...just have it fall both in front and behind? your way sounds the most awsome and simply done but.......yeah...knox'skorner rules
3D Joe Wiltshire
  • Winter's Coming :O
« Reply #11 on: March 05, 2008, 04:38:42 pm »
well. if you had a good editing programme you could add it in afterwards, or you could make lots of raindrops, taper a cylinder and tilt it sideways, then just add loads into your scene, but this would be very taxing on your render times
lynn22
    • 3D Animation
« Reply #12 on: March 05, 2008, 06:12:40 pm »
...just have it fall both in front and behind? ........
Then you will need terramin8or.
Attached is a log fire made with the same program. It's really life like when animated, it takes a long time to render but it's worth it.
