May 19, 2013, 12:35:37 am *
Pages: [1]
  Print
Author Topic: Best way to animate eyes-MORPHS or BONES ???  (Read 854 times)
Josmic8or
Full Member
anim8t & celebr8t
View Profile WWW
« on: May 04, 2010, 11:39:03 am »
To all of you who've had experience in animating characters in anim8or what's the best way to animate eyes-MORPHS or BONES Huh
DragonSlayer
Jr. Member
Now lets try to find that dragon...
View Profile
« Reply #1 on: May 04, 2010, 11:43:02 am »
I would say bones... but it could be a preference in many ways. If your eyes are part of your mesh, then morphs... but most eyes are separate from the head unless low poly, so most likely you'll want bones, because then you don't distort your eyes and they are easy to aim. If you use morphs, you would have to calculate the degrees the eyes need to rotate, and use the morph target accordingly, with bones you can guess and check.
daniel99
Full Member
View Profile
« Reply #2 on: May 04, 2010, 12:14:16 pm »
I ussualy animate both ways. I make morph targets with the rotation of the eyeballs and combinations (X+Y,-X+Y, X+-Y) but sometimes I also use bones. Personaly, I prefer morph targets because I believe the movement is more precise.
But both ways work just fine.
BOB_I_Ts
Full Member
View Profile WWW
« Reply #3 on: May 04, 2010, 05:02:26 pm »
I think eye balls should always be bone and the eyelids morph when animated
Sr. Member
View Profile
« Reply #4 on: May 04, 2010, 09:51:49 pm »
For a normal spherical eyeball as part of a figure I would suggest using bones, since they will allow the ball to rotate correctly.  Morphs move vertex points in a totally linear fashion, so the eyeball would actually distort through the morph tweeners.  Having said this, your model appears to use non-spherical eyeballs, so morphs might be the better option.
Josmic8or
Full Member
anim8t & celebr8t
View Profile WWW
« Reply #5 on: May 05, 2010, 05:56:05 am »
Actually my model has a spherical eyeball and it's separate from the head.I usually use morph targets to animate eyeballs but now I'm started to see the importance of using bones.
Thanx Guys!  Smiley Smiley Smiley
headwax
Sr. Member
View Profile WWW
« Reply #6 on: May 07, 2010, 12:25:19 am »
I like morphs personally
http://video.google.com/videoplay?docid=-7532295362301133499#
there's a tut on my site if you want details
see tutorail section on side bar here
you can see the varies bits floating around here http://video.google.com/videoplay?docid=-5981314379043041824#
cheese
Pages: [1]
  Print
Jump to:
Anim8orUsers
