May 23, 2013, 01:06:18 am *
Pages: [1] 2
  Print
Author Topic: Scripts Request: Edge to point or Faces to point!  (Read 2247 times)
Sr. Member
Neirao
View Profile
« on: July 27, 2010, 06:47:12 pm »
hi guys, somebody can maker this scripts? Smiley
are simples scripts i think then make changes in "POINTS to EDGE" script
this is possible..i try but i dont can make.. Cry
1 -  Edge to point ;
2 -  Faces to point;
one of two, already help me..
some moments i need make this selections..but anim8or not has this functions..
thanks so much all!
Gyperboloid
Full Member
It's better not to do anything, than to do nothing
View Profile
« Reply #1 on: July 28, 2010, 09:24:26 am »
Hi neirao! Smiley I tried this and had the same result, but then realized that it's not a bug Smiley
Sr. Member
Neirao
View Profile
« Reply #2 on: July 28, 2010, 12:26:29 pm »
ohh! thanks Gyperboloid!! Smiley
yes im try your way work..(but i think then Anim8or should make this turn automate..)
but thanks you help me so much
I tested turn to "points" and work too, and remove edges and points!!
 i needed this function! thanks!:)
Gyperboloid
Full Member
View Profile
« Reply #3 on: July 29, 2010, 07:45:00 am »
You wellcome Wink And neirao, one question: what prog do you use to create all these explanations? They are very nice Cheesy
Sr. Member
Neirao
View Profile
« Reply #4 on: July 29, 2010, 11:24:34 am »
hi Gyperboloid!
i use CorelDraw, i make printscreens and paste/crop
inside of CorelDraw, after export in .jpeg.  and send to ImageShark.com.
thanks! cheers! Smiley
« Last Edit: January 13, 2011, 03:50:20 pm by neirao » Logged
Sr. Member
Neirao
View Profile
« Reply #5 on: January 06, 2011, 04:57:18 pm »
Nobody can maker this script?? Sad
this is usefull for use with other script(not only delete points..)like:
- merge points
- flatten points
- move points etc..
 Smiley
« Last Edit: January 13, 2011, 03:51:29 pm by neirao » Logged
NickE
Full Member
View Profile
« Reply #6 on: January 13, 2011, 03:13:01 pm »
Neirao,
Attached is a script to do what you requested.  It will select the points of any edges and/or faces that are selected and de-select the edges and/or faces that were selected.
Edges and Faces are both handled by this single script.  I originally wrote a script for Faces and another script for Edges, then realized that there should not be a conflict having them in the same script.
Enjoy!
Sr. Member
Neirao
View Profile
« Reply #7 on: January 13, 2011, 03:27:24 pm »
UHUUU!! Cheesy
was what I was needing! Grin
Thanks Nicke!! Smiley
« Last Edit: January 13, 2011, 03:47:05 pm by neirao » Logged
Gyperboloid
Full Member
View Profile
« Reply #8 on: January 14, 2011, 04:04:49 pm »
Thanks to Steve we ( actually you guys ) can make a lot of interesting scripts  ( I wonna learn to write scripts too )Smiley
But neirao, you can do it without script, as I told you before and I think it's more quick ( so finaly, Anim8or have this "functione" Grin)
Select edges and just switch to points, as you already know . And the other is from faces to points like this: select a face, hit "t" shortcut ( or edit=>select=> select face edges ) and then switch to points Wink
Sr. Member
Neirao
View Profile
« Reply #9 on: January 14, 2011, 06:48:17 pm »
hi Gyper! Thanks! Smiley
the VISUALIZATION no is the right..
but yes, your way realy work,
Thanks! Wink
Gyperboloid
Full Member
View Profile
« Reply #10 on: January 15, 2011, 07:21:20 am »
 ???You mean my explanations are not so right writed Huh Yes I know Grin
Sr. Member
Neirao
View Profile
« Reply #11 on: January 15, 2011, 07:54:07 am »
Oh no Gyper.. Cheesy
not is "your explanations".. they is very good, i understand all ok Smiley
is the "Anim8or visualization" then no is right,
Anim8or should "show the points selecteds" in this case..
Sorry is because, im not "speak" english very well ok! Roll Eyes
im brazilian..
« Last Edit: January 15, 2011, 07:56:05 am by neirao » Logged
Gyperboloid
Full Member
View Profile
« Reply #12 on: January 16, 2011, 03:21:19 pm »
First , I don't speak english well too Cheesy Second, I am very lazy Grin . But I think evrybody can understand what I mean. If you mean the pictures I posted, I think I know what you mean. The third pic, yes ? If so then , there is one thing : when you ahve selected an edge and then you switch to points, the edge is still showed selected ( white ) but actually the points are. Never mind, you understood and I don't think there will be a problem if some newbie will read this. One is sure : we have learn some english here  Cheesy
Sr. Member
Neirao
View Profile
« Reply #13 on: January 16, 2011, 05:05:23 pm »
Wink
benzjie
Jr. Member
View Profile
« Reply #14 on: April 01, 2012, 03:07:02 am »
bumping this " old" topic.  But is it possible to have a script that lets you select edges ( q or Q)  and than select the faces ?
( select two rows of edges wityh q or Q , script selects the inbetween faces)
This would come in very handy whilst UV mapping.
Pages: [1] 2
  Print
Jump to:
Anim8orUsers
