Pages: 1 2 [3] 4 5 ... 9
Author Topic: My new project  (Read 38772 times)
CoriDavis
  • Scámarca Productions
Re: My new project
« Reply #30 on: September 08, 2010, 09:40:12 pm »
Ok, so I took a really long break after I lost half of the project, but now I finished the body! now I just have to make the mane and tail
3Dgeek11
  • Roll Tide.
    • My DeviantART
Re: My new project
« Reply #31 on: September 08, 2010, 11:35:39 pm »
Hmm, it looks great! But I do see a few areas here and there that may require some touching-up. ;)
Keep it up! :)
CoriDavis
Re: My new project
« Reply #32 on: September 09, 2010, 12:18:23 am »
Ok, when I tried to UV the mane, the picture doesn't move.  what's going on?
CoriDavis
Re: My new project
« Reply #33 on: September 13, 2010, 10:33:32 pm »
ok, fixed the UV, now to have my first go at skinning! I hope I can do this..
CoriDavis
Re: My new project
« Reply #34 on: September 18, 2010, 05:50:03 pm »
here's my walk test for my model! the cross-section tail idea didn't work as well as I planned, any suggestions?
http://tinypic.com/r/20af6ep/7
3Dgeek11
  • Roll Tide.
    • My DeviantART
Re: My new project
« Reply #35 on: September 18, 2010, 07:10:51 pm »
That horse looks great! So does the walk-cycle. :)
I don't have any suggestions for the tail, except to make a "tail" that has depth instead. ;)
If you want help with that, just ask. ;)
CoriDavis
Re: My new project
« Reply #36 on: September 18, 2010, 07:31:19 pm »
oh and one other thing, if I import the object to make another character, will the morph targets be imported as well?
3Dgeek11
  • Roll Tide.
    • My DeviantART
Re: My new project
« Reply #37 on: September 19, 2010, 09:21:58 am »
Ask someone else, I've never dealt with morph targets...
Maximilianibus
  • Bla Bla Bla, Mr Freeman!
    • Please Subscribe!
Re: My new project
« Reply #38 on: September 19, 2010, 02:07:50 pm »
wow, nice!
CoriDavis
Re: My new project
« Reply #39 on: September 22, 2010, 11:58:29 pm »
Ok, so every time I get on my file there's 57 missing items because I imported my skeleton from the cursed horse to build my figure on and I told it not to bring in the items.  is there a way to delete missing items?
Janro
Re: My new project
« Reply #40 on: September 23, 2010, 03:24:54 am »
Pretty good model and animation. If I may suggest something for the tail, you could try what some videogames do. Have a cylinder shape to take its place. Then up to you if you can build an alpha texture that goes transparent near the end to produce the soft/hair effect.
Morph targets are copied when either imported or copy-pasted. The latter gets annoying when you just copy paste one part ><
As for the missing items, the only thing way I get around that is to delete everything that is attached to the skeleton before importing it into the other project file. I don't know how to remove it in your new project file without having to go into text editor.
CoriDavis
Re: My new project
« Reply #41 on: September 23, 2010, 07:14:21 pm »
oh, I see. can you tell me about Text editor? how will that get rid of it?
CoriDavis
Re: My new project
« Reply #42 on: September 23, 2010, 08:23:48 pm »
ugh.. I had the key frames from the walk sequence, but now I can't get rid of them!  I want to  use my scene over, and I delete all the keys from the walk sequence, then I switch from scene mode to sequence mode or something, and they all come right back!  same thing when I undo something, it doesn't go away!
Janro
Re: My new project
« Reply #43 on: September 24, 2010, 01:01:04 am »
I'm not too familiar with the way the way the text editor is built actually. I just assume that it is possible. It will be a very long process. I'd suggest just saving a copy of the original then deleting the objects attached to the figure and then importing.
I've had that problem regarding deleting sequences. From what I gather it's like permanently gluing the frames in there. The only way around it is to delete the figure and then put in a new one.
Last thing, I'd suggest you use modify post button instead of double posting. Unless you want to bump your thread. ^_^
CoriDavis
Re: My new project
« Reply #44 on: September 24, 2010, 02:01:38 pm »
oh yeah, good idea. usually I do, but sometimes I forget.  normally if I double post it's because I modified something in my project, or I have an urgent problem (urgent meaning I get impatient, lol).  you know what someone should do? someone should make a thing like facebook where you can post anim8or project updates! lol, I wonder if I could accomplish that...
Oh and deleting the figure worked by the way
« Last Edit: September 24, 2010, 02:11:30 pm by CoriDavis »
