May 25, 2013, 07:49:51 pm *
Pages: [1] 2
  Print
Author Topic: Very Important: importing PNG-files!  (Read 3495 times)
Maximilianibus
Full Member
Bla Bla Bla, Mr Freeman!
View Profile WWW
« on: December 10, 2010, 07:21:26 am »
hey guys! many images in the www are pngs... so make them compatibel! Grin
lynn22
Sr. Member
View Profile WWW
« Reply #1 on: December 10, 2010, 08:27:44 am »
Why would that be a requirement ?
Convert your image to a format that can be imported.
Also, remember that most images on the www are copyright of the poster and may not be available for others to use.
Maximilianibus
Full Member
View Profile WWW
« Reply #2 on: December 10, 2010, 10:59:45 am »
well, but i prefer using pngs and bmps than gifs or such
3D Joe Wiltshire
Sr. Member
Winter's Coming :O
View Profile
« Reply #3 on: December 11, 2010, 06:22:30 pm »
Jpegs ftw Smiley
novocas7rian
Newbie
View Profile
« Reply #4 on: December 12, 2010, 06:17:27 pm »
PNG support would be nice though especially if anim8or supported alpha mapping in textures, and rendered shadows accordingly.
For instance, creating a rectangle, IV mapping a texture of a tree onto it with transparent background, and the "ground" under the tree has the tree-shaped shadow when rendered rather than a box, as happens in Povray.
Sr. Member
View Profile WWW
« Reply #5 on: December 14, 2010, 12:03:42 pm »
Ah i don't really like jpg's, they're sooooo low quality and png's look so much better. Oh yeah novocas I have absolutly no idea what ur talkin about.
Maximilianibus
Full Member
View Profile WWW
« Reply #6 on: December 14, 2010, 03:28:30 pm »
I think He means the correct render of alpha maps
novocas7rian
Newbie
View Profile
« Reply #7 on: December 15, 2010, 04:42:46 pm »
Sorry if I'm not clear - I'm rushed for time right now else I'd setup an example in povray to illustrate.
Yes, I'm talking about correctly rendering alpha maps, which PNG would support, but also rendering _shadows_ of alpha-mapped-textured objects correctly.  In my "tree" illustration, the object is just a rectangle, so if its treated as a solid as anim8or does now, you'd see a rectangular shadow cast by it.
If the rectangle, however, is textured with a PNG that uses transparency, it'd be great if the shadow also used the alpha map of the texture.  For instance, if the rectangle is textured to a tree, you'd ideally see the tree being rendered and other objects behind it (eg support for the alpha maps) and you'd also see the tree cast a tree-shadow, not the rectangular shadow of the object its mapped onto.  Hope that makes it clearer.
Sr. Member
View Profile WWW
« Reply #8 on: December 19, 2010, 10:29:28 am »
Ok, that makes much more sense.
spicy
Sr. Member
View Profile WWW
« Reply #9 on: December 21, 2010, 03:31:43 pm »
Jpegs ftw Smiley
I prefer PNG's over GIF's and JPEG's.
I agree, and the fact that they support transparency is a bonus.
Sr. Member
View Profile WWW
« Reply #10 on: December 21, 2010, 04:21:32 pm »
Yup, transmaps would probably become obselete if Anim8or supported PNG's w/ transparencies.
Maximilianibus
Full Member
View Profile WWW
« Reply #11 on: December 21, 2010, 06:34:55 pm »
Well, yeah. But Actually i thought, if i eg Need a Wood textur,  90% of the good Images are pngs  Undecided
Global Moderator
Hero Member
View Profile
« Reply #12 on: December 21, 2010, 07:02:18 pm »
PNG's are easy to convert to a usable format, so don't eliminate the option of using those textures.  I do agree, PNG's would be a wonderful feature, the issue is this feature's been requested a thousand times already, and most people want it.  I believe Steve knows people want it to be implemented, he just hasn't gotten around to it yet, as he's a very busy man!
Sr. Member
View Profile WWW
« Reply #13 on: December 21, 2010, 07:07:18 pm »
I think Steve's given up on Anim8or and doesn't have the heart to tell us. But yeah, PNG's are easy enough to convert, just they lose so much quality.
Kyle
Full Member
View Profile
« Reply #14 on: December 29, 2010, 08:50:03 pm »
then why not pass the torch  by making it open source?
Pages: [1] 2
  Print
Jump to:
Anim8orUsers
