Author Topic: What is map transparency  (Read 1746 times)
SValera
    • http://anim8or.far.ru/
« on: April 11, 2011, 07:01:09 pm »
What is map transparency as its make and use
Re: What is map transparency
« Reply #1 on: April 11, 2011, 08:50:46 pm »
I think you mean a transparency map. This is a black and white image you can add to your material. The black parts of the image will be transparent in your render, while the white will be visible. With such a map you can easily make objects which are hard and time-consuming to model: like leaves, grids, hair etc
Read more about the use here: Advanced textures
