Pages: [1] 2
Author Topic: Shadows done, now on to mirrors and glass...  (Read 9952 times)
Pirate92
« on: March 21, 2008, 01:36:36 am »
Here is a picture I whiped up. But I had to replace the ground grid With a made by me floor, because the ground grid will not receve shadows.
Immage outdated, and deleted. Look further down.
« Last Edit: March 22, 2008, 10:39:22 pm by Pirate92 »
I do not stoop so low as to pick favorites from the congregation!
I hate everybody equally.
Re: Excelent shadowing, but the ground grid will not receve shadows.
« Reply #1 on: March 21, 2008, 04:19:11 am »
Are you sure?  What kind of light are you using?  They render for me when I use the default lights and a spotlight.
Pirate92
« Reply #2 on: March 22, 2008, 09:47:37 pm »
I have attampted agen, and found that the ground grid does not accept shadows like it use to in older versions. You must use the ART ot render with shadows, and I did not know that.
« Last Edit: March 22, 2008, 10:00:12 pm by Pirate92 »
Pirate92
« Reply #3 on: March 22, 2008, 10:03:16 pm »
Ok it's done right this time!
Pirate92
Ok Shadowing done. Now, on to reflections!
« Reply #4 on: March 22, 2008, 10:04:58 pm »
Ok, I need a step by step instruction tutorial for making mirrors and glass, with pictures. If there are no pictures I am unable to get it. Yes, I'm dislexic.
« Last Edit: March 22, 2008, 10:37:42 pm by Pirate92 »
Pirate92
Re: Shadows done, now on to mirrors and glass...
« Reply #5 on: March 22, 2008, 10:43:16 pm »
PS. Steve, will you be (In future) adding a little check box 'Mirror' with a box to set the power of the reflection? (Same for glass)
« Reply #6 on: March 22, 2008, 10:47:07 pm »
Pirate, have you downloaded the example files and looked at those?  They're very helpful.
« Reply #7 on: March 23, 2008, 02:40:42 am »
Yes, that's a bug.  The scanline renderer's shadwos don't work on the ground grid.  I'll fix it.
flametiger74
« Reply #8 on: March 23, 2008, 04:19:32 am »
Yes. I agree with Pirate92. I would want a sort of material organizer. Or in the regular material editor have a label and a text box for reflection
i.e.
Reflection: <Text Box>
enter a # between 0.000 and 1.000
0 being no reflection and 1 being perfect mirror.
Now I relize that with the system Steve is creating there is more power as to what properties the reflection has (i.e. Glossy reflective.)
Also one thing I noticed. You can't copy materials if they are in file and not object tab.
Thanks steve.
« Reply #9 on: March 23, 2008, 04:59:19 am »
I have the same problem with copying materials, but I only can't copy with "ctrl + shift + c" in this mode.  I can still go "edit>copy material"
Tanzim
« Reply #10 on: March 23, 2008, 06:39:57 am »
actually what Steve did was pretty smart (as compared to what you want him to do)
specular is a fast way of doing reflection's, as it only reflects white light regardless
adding the specular attribute with the string reflection changes the specular value into reflection value, so only either specular or reflection has to be computed instead of both
also materials in file will appear throughout the file so it would be pointless having it copied, object materials only appear in the object
Hope that helps
flametiger74
« Reply #11 on: March 23, 2008, 06:41:45 pm »
Well the point I'm trying to make is not that you can't copy file materials, but from one project to another.
Normally if the objcets material is in the object tab. You can just copy the object and paste it in another object and the material will be copied.
With file the material won't be copied.
« Reply #12 on: March 23, 2008, 06:46:30 pm »
Ah, I see what you mean now.
If you're using the newest version of anim8or (v0.97a) you can copy and paste materials straight from the bar with "edit>copy material" and "edit>paste material".  You can do this from project to project as well.
Pirate92
« Reply #13 on: March 24, 2008, 03:20:23 am »
Yes I did. I'm just not the remembering kind of guy.
« Reply #14 on: March 24, 2008, 05:14:56 am »
Then do what I did!
Save the files to your computer and whenever you forget, just go back to them.  It's the same as a tutorial, if you aren't the remembering kinda guy you'd have to go back to the tutorial anyways.
Pages: [1] 2
