Author Topic: modeling rooms/buildings...  (Read 1892 times)
TheRetroZombie
  • I do crap animations.
    • Youtube Channel
« on: July 23, 2011, 01:39:00 am »
Decided to start creating buildings with indoors now it seems pretty difficult to do in Anim8or, is there any software to use to create these?
X
dwsel
    • Dwsel art
Re: modeling rooms/buildings...
« Reply #1 on: July 23, 2011, 02:19:37 pm »
Could you be more specific about encountered problems i.e. show some blueprints or hand drawings of what you're trying to achieve? I'm interested in making visualizations (2 interiors and exterior behind me in Anim8tor) and beside importing *.dxf and sometimes unwrapping I had no main issues in Anim8tor. If you mean huge timeprint to build everything by hand from beginning then yes... it takes some time and patience to fully populate your interior with various objects. You can download them (preferably in *.obj or *.3ds format) from various places and recreate textures and materials and it will save some time, but still...
If you have specific problem in your workflow (Anim8tor or other apps) I may be able to help.
Kyle
« Reply #2 on: July 24, 2011, 02:01:18 am »
Some random advice I can give from my experience modeling Andy's room: First, decide how much you really need. Assuming you want it to look good from every angle, the first problem you'll quickly find is that its hard to see what your doing. My solution to this is to do the following.
Make your wall, floor and ceiling materials double sided with the back faces transparent. This lets you see inside at all times even though your on the other side.
Make sure your faces are inverted or else it wont get lit properly.
make the ceiling a separate object. this allows you to keep it hidden when modeling to more easily select various props form the top view. also, I'd suggest not keeping  the ceiling a paper thin face. shell it a bit
Once you have placed enough props/furniture you should start to have enough to allow you to work blind. as is when you hide the walls/floor mesh while fleshing out other details.
I usually try to model props in a separate object, but copy/paste them into the main object later for adjustments. Its definitely a good idea to see what they look like inside the room first, as opposed to just adding it in scene mode. This allows you to keep scale in perspective while deciding the size of things.  Ive tried doing every prop as a separate object in scene mode and its just a mess as far as scale.  Try to have some kind of reference point, maybe even a stand in for a  human so you know what how large you want things to be.  Scale is one of the most important things for a room to feel right. It takes a lot of fine tuning and constant adjusting.
the perspective view in can be useful in modeling mode, just make sure you make the room a good size for it. make it too small and it'll be hard to keep its axis centered, make it too big and it'll clip the camera a lot causing a lot of distortion.
