Pages: [1] 2
Author Topic: New preview with XP fix ready: v0.97f  (Read 10673 times)
« on: October 02, 2013, 09:55:37 pm »
I just uploaded a new Anim8or (v0.97f) with the following fixes:
- Fix 097e-101 - Incompatible with Windows-XP.
- Fix 097e-102 - Requires MSVCR110.DLL to run.
- Fix 097e-103 - Add edges to a mirrored object when the end point is an axis point duplicates the point.
- Fix 097e-104 - Select orphans can leave on point unselected.
- Fix 097e-105 - Viewing OpenGL info crashes.
- Fix 097e-106 - Adding edge as new mesh (shift-click-drag) crashes.
- Fix 097e-107 - Add Windows Vista, Windows 7 and Windows 8 to OS Information dialog.
- Fix 097e-108 - Knife tool does not cut all the way on the mirrored side, when starting from a point.
- Fix 097e-109 - UVs do not get mirrored when using the Texture UV tool.
- Fix 097e-110 - Mirrored Mesh: Subdividing a face of a mirrored mesh in the point editor crashes.
            (Was: When manipulating the added mesh data within a subdivided face
             (Edit->Subdivide Faces), erroneous results occur.)
- Fix 097e-111 - Subdivision Mesh: When 0 working divisions, stays non-shaded when in point edit mode,
   regardless of shading mode.
- Fix 097e-112 - Materials: If the specular and emissive factor isn't change from the default,
  then it doesn't get saved in the .an8 file even when a texture is applied to that channel.
- Fix 097e-114 - Add Edge tool: Starting a new mesh with the Add Edge tool (by shift-click-dragging) causes crash.
- Fix 097e-115 - Convert to Mirror: Edges not in faces are lost when converting a Mesh to a Mirrored Mesh.
  Also added automatically convert parametric objects into a mesh.
- Fix 097e-116 - User Interface: Vertical Resize Bar: Behaves erratically when click-dragging it.
- Fix 097e-117 - Sequence data fails to save: Sequences save as empty keyframes in the file.
- Fix 097e-118 - Sequence data from older versions fails to reload properly.
- Fix 097e-121 - Splash Screen: Mode->Object comand crashes when initial project is loading.
I have not fixed these known issues yet but I am working on them:
#097e-113 - Bevel tool: destroys UVs of surrounding faces.
#097e-119 - Morph Targets: Do not work with Mirrored Meshes.
#097e-120 - Background images: Appear dark in the workspace and when using the opengl renderer.
There are also a couple of minor new things:
- Add option to restore window position in next session.
- Enhance face properties dialog to show more information.
You can download a copy here:
Anim8or v0.97f XP Compatible Preview
!!!!!!!!!!! I fixed the link (again!) My web-site editor and I don't always agree on where files should be :)  !!!!!!!
« Last Edit: October 14, 2013, 07:18:12 pm by Steve »
johnar
    • youtube vids
Re: New preview with XP fix ready: v0.97f
« Reply #1 on: October 03, 2013, 12:27:12 am »
  Hi there Steve.
 Downloaded and opened on XP. Had a quick play around. So far so good. Awesome!!
Man you've been busy. This is beyond Gr8. Thank you, thank you, thank you, very very much.
 Can't wait to get some projects happening with v0.97f.
 Massively Awesome.
« Reply #2 on: October 03, 2013, 01:08:28 am »
Hey Steve, thanks for the hard work!
Couple of bugs:
  • Flat Shaded view no longer works (remains smooth shaded)
  • With a subdivision object with 0 working divisions, the smooth angle does not visually update until you OK it twice
  • With a subdivision object with 0 working divisions, in Wireframe View faces have double the opaqueness in point edit mode than the other modes.
headwax
    • Headwax's Website
« Reply #3 on: October 03, 2013, 06:24:54 am »
thanks Steve, muchos gracias :) as we say in Oz.
« Reply #4 on: October 03, 2013, 09:10:02 pm »
Raxx, do you have shaders enabled?  If so this explains the lack of flat shading.  This is a known issue.
The double opaqueness occurs because both the mesh and it's controlling shell are drawn.  For a subdivision of 0 they are the same surface.  I'll see if I can find an easy way to fix this.
« Reply #5 on: October 03, 2013, 09:13:27 pm »
headwax: Hey, I didn't know that muchos gracias was auzzie talk  :)
johnar: I'm relieved to finally get XP working. MS is such a pain - they're trying to kill it even though half of the Windows computers users still prefer it.
headwax
    • Headwax's Website
« Reply #6 on: October 04, 2013, 04:11:27 am »
ha hah, we like to keep our special talk to ourselves but occasionally out it escapes :)
« Reply #7 on: October 04, 2013, 03:23:29 pm »
Whoops
I figured as much, but I didn't like it compared to the original opacity so I thought it was worth a mention.
Thanos
« Reply #8 on: October 05, 2013, 08:32:13 pm »
Working on win7 and Fedora 17 with wine. Thanks a lot, Steve, glad to see you back.
I noticed some bugs with the smooth-flat-wire buttons (maybe related to Raxx's bug?). I have shaders enabled:
- win7: Flat doesn't work, shows smooth instead
- linux: Tried rolling between smooth-flat-wire buttons a couple of times, and noticed a per-button lag: ie. pressed smooth, then pressing flat activated smooth, then pressing wire activated flat, then pressing smooth activated wire etc.
...hope this helps (TM)
« Reply #9 on: October 05, 2013, 09:16:13 pm »
OK I'll look into flat shading and the double transparency a bit more to see if I can improve things.
« Reply #10 on: October 07, 2013, 12:51:30 pm »
Options/Debug/Morph Normals
If this allows morph normals to be exported to the file,then it doesn't work in version e and f.
If it's something else, it would be nice to know
so that I could add morph normal output to the
feature request list.
ianross
« Reply #11 on: October 07, 2013, 01:17:51 pm »
Bug report, firstly thank you Steve, it opens up in XP. In the scene mode when I tried to render a two sided material i.e a 2d render  version 0.97f shut down.
I used scanline renderer.
« Reply #12 on: October 08, 2013, 03:35:09 am »
Thanks, Claude and ianross.  I'll look into these.
« Reply #13 on: October 11, 2013, 03:54:24 am »
try this link, I`m getting a 404 Error now on the original link
[Steve] I fixed it (again!) Sorry about the problems, everybody. Here's the new place:
Note: I also deleted several messages about the broken link so this topic will be easier to read.
[/Steve]
« Last Edit: October 14, 2013, 07:29:26 pm by Steve »
SubDrag
« Reply #14 on: October 12, 2013, 08:16:03 pm »
Not sure if supposed to report bugs here, but, one of the bigger problems I have, is certain bitmaps will open in anim8or. But when you export to .obj, bam anim8or crashes.
Pages: [1] 2
