Pages: 1 [2]
Author Topic: Remove the Viewpoint mode from all editors?  (Read 15623 times)
Re: Remove the Viewpoint mode from all editors?
« Reply #15 on: July 29, 2015, 10:30:52 pm »
Rotate bug?
What rotate bug? It seems to work fine as is...
Trev
In viewport mode rotate tool does not work in any view apart from perspective.(build 1179)
« Last Edit: July 29, 2015, 10:31:20 pm by kreator »
captaindrewi
  • errm...errr?
« Reply #16 on: July 29, 2015, 11:40:17 pm »
Well, if the only thing preventing the viewpoint button from being removed is the lack of a middle mouse button alternative for zooming, why not add an option to where it's done by holding both left and right mouse buttons?
sounds good
nemyax
« Reply #17 on: July 30, 2015, 10:24:53 am »
sounds good
Seconded.
Trevor
    • LS Tech Services
« Reply #18 on: July 30, 2015, 01:09:46 pm »
Oh, well in that case lower my percentage of useage to 10% because I never noticed that... I guess I use Alt more often than I thought.
Trev
captaindrewi
  • errm...errr?
« Reply #19 on: July 30, 2015, 01:35:31 pm »
Rotate bug?
Trev
is this universally true?it seems to be performing as expected for me unless i'm missing something,which is always a possibility. :)
enclosed vid shows me using arc rotate in viewport mode without any obvious setbacks. unless as i say i'm not understanding.
« Last Edit: July 30, 2015, 01:40:58 pm by captaindrewi »
« Reply #20 on: July 30, 2015, 04:06:52 pm »
captaindrewi, the issue is with using the rotate tool in viewpoint mode, which is supposed to do the same thing as the arc rotate's rotation function. Go in viewpoint mode, click on the Rotate View button (<r>) in the left-hand toolbar (not the arc rotate button in the top toolbar), and try rotating around.
captaindrewi
  • errm...errr?
« Reply #21 on: July 30, 2015, 05:04:23 pm »
ah i see..thanks for clearing up my foggyness :)
« Reply #22 on: August 03, 2015, 04:46:47 pm »
Another option is to add three icons onto the viewport/workspace (top right corner, probably), where you click and drag on one and it pans the view, click and drag on another and it rotates the view, click and drag on the other and it scales the view.
sounds suspiciously like a variation on the theme of widgets 8)
it adds more noise to the workspace
am tempted to say "what if they only appear when you activate Arc Rotate", but i'm sure somebody would come back and say that isn't newbie-friendly... which is probably true :(
8or
« Reply #23 on: March 23, 2017, 02:21:47 am »
Responding because of V1.0 Beta.
Please do not remove it. Or at least make it enable-able from some options mode.
Please also add optional middle mouse rotate to match the functionality of some other 3d editors. Middle mouse scroll already can zoom, please add rotate too.
Pages: 1 [2]
