Pages: [1] 2
Author Topic: An8Helper  (Read 5743 times)
An8Helper
« on: January 11, 2016, 10:14:05 am »
Here's a small tool that enables fullscreen and menu bar auto-hiding.
  • Press F11 to enter fullscreen when in Anim8or
  • Press Shift+F11 to toggle the auto-hiding of the menu bar
  • A tray icon appears in the tray area of your windows task bar. Right-click for options
This isn't meant to be a big supplementary app for Anim8or, just trying out a full screen effect. It doesn't modify the Anim8or code, but rather modifies parameters on the Windows side of things. Use at your own risk.
« Last Edit: January 12, 2016, 03:20:45 am by Raxx »
Re: An8Helper
« Reply #1 on: January 11, 2016, 02:10:00 pm »
Wont run on Windows 10 Raxx >:(
Scrub that it will not run on a Windows 10 Tablet, but works fine on my Laptop and Desktop both running Windows 10.
« Last Edit: January 11, 2016, 07:49:15 pm by kreator »
Re: An8Helper
« Reply #2 on: January 11, 2016, 03:46:33 pm »
It works OK.
WIN 7
ronaldefarmer
    • Ron's Website
Re: An8Helper
« Reply #3 on: January 11, 2016, 06:25:54 pm »
This is a great idea, Raxx!! It works on Windows 8. It seems to cut of the top half of Anim8or's menu bar on this particular computer, but that's not a big deal.
ronaldefarmer
    • Ron's Website
Re: An8Helper
« Reply #4 on: January 11, 2016, 06:37:54 pm »
It seems to cut of the top half of Anim8or's menu bar...
Actually, This only happens if the Anim8or window is maximized when F11 is pressed. Otherwise it works perfectly.
Re: An8Helper
« Reply #5 on: January 11, 2016, 08:38:36 pm »
Glad it sorta works kinda. That's usually the case when I make these things using the quickest dirtiest methods. I uploaded a new build that fixes the pre-maximized cut-off issue.
Kreator, not sure why it doesn't work on your tablet. Have you tried adding it as an exception to your antivirus and/or tried running as administrator? Does it at least load the tray icon?
I expect that if Steve tries it and likes it, he might add this feature to Anim8or and make this app redundant, which is fine with me. Then I can go and make something else that sorta works kinda.
« Last Edit: January 11, 2016, 08:38:58 pm by Raxx »
Re: An8Helper
« Reply #6 on: January 11, 2016, 09:03:41 pm »
Nifty, raxx.  The F11 full screen key is nice.  I've tried to figure out how to change the colors of the menu bar to the gray and orange scheme but so far without much progress.
Re: An8Helper
« Reply #7 on: January 11, 2016, 09:40:35 pm »
Glad you like it! Yeah, the menu bar in Windows seems pretty primitive even after all these years. I spent a while trying to figure it out myself.
I think the best options are to either use the .Net framework, GTK+, or create your own from scratch.
ronaldefarmer
    • Ron's Website
Re: An8Helper
« Reply #8 on: January 12, 2016, 02:53:46 am »
It doesn't seem to work on my old Toshiba Satellite running Windows 7. I get this message:
« Last Edit: January 12, 2016, 02:57:32 am by ronaldefarmer »
Re: An8Helper
« Reply #9 on: January 12, 2016, 03:21:10 am »
Whoops. I forgot long ago that I was working on a 64-bit system. Attached to the first post is the 32-bit version. This might also solve kreator's issue.
« Last Edit: January 12, 2016, 03:21:18 am by Raxx »
ronaldefarmer
    • Ron's Website
Re: An8Helper
« Reply #10 on: January 12, 2016, 04:22:47 am »
That did it...it now works flawlessly on my Satellite. Thanks for doing this!
Re: An8Helper
« Reply #11 on: January 12, 2016, 05:50:31 am »
@ronaldefarmer No prob, glad it works!
Re: An8Helper
« Reply #12 on: January 12, 2016, 06:10:48 am »
Thanks Raxx, that appeared to be the problem! Who`d believe my tablet is running 32
Bit ... i certainly was not aware of it  ::)
« Last Edit: January 12, 2016, 12:26:21 pm by kreator »
johnar
    • youtube vids
Re: An8Helper
« Reply #13 on: January 12, 2016, 08:23:30 am »
 This is cool Raxx
 Works gr8. My 40 inch monitor seems even bigger now. Nice one. Thanks for that.
Hypure
Re: An8Helper
« Reply #14 on: January 17, 2016, 03:32:43 am »
Looks great
Pages: [1] 2
