Author Topic: SCRIPT REQUEST! - OBJECTS to NEWS OBJECTS IN MENU!  (Read 2980 times)
« on: January 04, 2017, 07:03:50 pm »
can someone to create this script? ::)
i not remember if has something like it :)
mayimchay
Re: SCRIPT REQUEST! - OBJECTS to NEWS OBJECTS IN MENU!
« Reply #1 on: February 27, 2017, 01:56:02 am »
Haven't touched ASL in a while, but this seems possible. Probably a plugin would be best for this so you can make custom figures. The primitives required would be spheres (for the head and joints) and cylinders for the bones when rigging.
The only downside is you'd have to rig the body manually in figure mode (unless ASL has support for scripting bones). There's a couple good plugin script writers around.
I like the visual format of your questions neirao. It's very clear what you're asking for. Great suggestion!
« Reply #2 on: February 27, 2017, 08:06:34 pm »
Currently there is no way to create a new Object in ASL, so the obvious way of doing this won't work.
I suppose you could write an export script that writes a complete .an8 file containing all the separate Objects, then read that back in. This would be a lot of work however. What's really needed is a way to create new Objects directly in ASL.
benzjie
« Reply #3 on: March 09, 2017, 03:38:49 pm »
How about going to object mode, select faces, press shift-d and repeat that ?
