Author Topic: Rendering faster without preview  (Read 2411 times)
Nellucnaiv
« on: October 03, 2017, 05:37:06 pm »
Hi all. Is it possible to render a movie clip using Art without the preview. I understand it's slow and requires patience but the preview obviously slows it further using up RAM too. Is there a setting I don't know of. I'd appreciate any advice.
Thanks in advance,
Ian
Re: Rendering faster without preview
« Reply #1 on: October 03, 2017, 05:49:02 pm »
Main Menu
File/Edit/ConfigUI
Uncheck Show Progress
in Render Preview.
Hope that helps Ian!
Nellucnaiv
« Reply #2 on: October 06, 2017, 05:43:07 pm »
Hi kreator,
Thanks a ton. Easy to miss the smaller stuff!
Gyperboloid
« Reply #3 on: October 06, 2017, 10:25:39 pm »
But remember to render a single image to check if everything shows right or you may be bad surprised after, say, some hours of continuous "nopreview" rendering. Say you were waiting 32 hours and all you get in the end are 325 frames of "Malevich's well known painting" .   :D
« Last Edit: October 06, 2017, 10:27:31 pm by Gyperboloid »
« Reply #4 on: October 07, 2017, 09:36:55 am »
Thats why its better to render a movie as a series of images , then you can start from the last one rendered if anything untoward happens!
« Reply #5 on: October 07, 2017, 01:05:51 pm »
Thats why its better to render a movie as a series of images ...
i only got into this habit relatively recently, but i can vouch that it's a good one.  also, if you go the separate-frames route, then you can use PNG instead of BMP to save a lot of disk space without any noticeable drop in image quality.
Nellucnaiv
« Reply #6 on: November 17, 2017, 05:12:35 pm »
Sorry guys, I somehow missed your last posts....quite a while back! Thanks a lot for sharing your knowledge, I appreciate it
