Pages: 1 [2] 3
Author Topic: script request-copy along a spline  (Read 26760 times)
Re: script request-copy along a spline
« Reply #15 on: June 20, 2008, 07:23:57 am »
NickE: Yep thats exactly what I am referring to at the moment, you must stick a target in so that the object can follow , it would be so much nicer to have a path then the object can follow that ...... there is a "Follow Path" In the Scene Editor Menu under BUILD but that Has not been Implemented at the moment .....it would be so much better if it was.
This program will only get better when all these little things are implemented,
I know this is totally off topic but the other thing that niggles me in anim8or whilst in scene mode, is the total inability to Copy/ paste duplicate objects (Carrara Pro 5 has this )
Orange Pickle
« Reply #16 on: June 20, 2008, 07:35:24 am »
Thanks karate5662 for the tutorial and NickE for the script!
karate5662
    • my mini city
« Reply #17 on: June 20, 2008, 05:31:14 pm »
no problem pickle
I agree with that.
this animation would have taken 2-3 hours if i could have copied and pasted in scene mode. instead, it took 4 days:
« Reply #18 on: June 20, 2008, 06:50:21 pm »
What do you need to copy?  Objects?  Or Objects and all of thier controllers, dependendencies and other properties?  The same question applies to the paste operation.
karate5662
    • my mini city
« Reply #19 on: June 20, 2008, 08:05:44 pm »
it would be nice to copy and paste objects and their keyframes.
Another feature i would like is to be able to make closed paths in scene mode that would be like splines but the object on the path keeps going after it gets to the end, like a loop.
lynn22
    • 3D Animation
« Reply #20 on: June 25, 2008, 10:10:16 pm »
I tried this script today and got the same error as kreator.
Attached is the Debug Output
I made sure there were not typos in the names of the spline and mesh, which was just a small ball.
I must be missing something, a push in the right direction would be helpful, many thanks.
NickE
« Reply #21 on: June 25, 2008, 11:14:46 pm »
lynn22,
In those early scripts, I forgot to put error checking to insure that you actually have a mesh called "copytarget" and a spline (path) called "copypath".  In the case of the error you posted, it is caused by NOT having a mesh called "copytarget" present.  If I get time, I will post an updated version of that script with error checking.
lynn22
    • 3D Animation
« Reply #22 on: June 26, 2008, 06:56:01 am »
NickE, when I left here last night I tried again.
Drew a spline, called it copypath and a little ball, called it copytarget, selected both and made attached screenshot.
Then I clicked on the script button and on the edit window and I still got the same error messsage.  ???
« Reply #23 on: June 26, 2008, 07:04:22 am »
Seems to me that the Lynn22 action, has something to either do with memory or pagesys...
Every time I try on my little laptop at work the function does something as it writes the result to debug console but no parametric shape appears on the GUI....now the laptop only has about 200md when fully loaded.
If I do the same operation from home on my desktops that have 2gb memory , i have no problem whatsoever .,
« Reply #24 on: June 26, 2008, 09:04:49 am »
Convert the sphere to mesh.  Try it then.
karate5662
    • my mini city
« Reply #25 on: June 26, 2008, 12:32:01 pm »
kreator had that problem when he first tried to use the script with a parametric cube. this script only works with meshes, convert it to a mesh.
lynn22
    • 3D Animation
« Reply #26 on: June 26, 2008, 06:05:45 pm »
Sorry, I tried it with both parametric and mesh and I got the same error message each time.
I guess it must me my PC, it's an old work horse so it may be reluctant to learn new tricks ;)
« Reply #27 on: June 26, 2008, 06:55:07 pm »
It definately is a memory problem.... I tried it on another computer with 64Mb memory.... and it would not display anything to the GUI  , although debug is showing 24 objects created .
And as a point of note i did convert the base object to mesh before starting
take a parametric Shape to be a standard cube.... ie The bounding box is yellow as opposed to a mesh (White bounding box).... anyway i used the cube first to get that error ... converting it to a mesh does nothing for me just sits there.
  • Neirao
script request-copy along a spline - WHERE IS FOR DOWNLOAD ??
« Reply #28 on: July 05, 2008, 06:04:34 pm »
Please NickE,
where is the script "meshpath in a8s" for DONWLOAD??
i donīt found... ??? ???
referent in this video  http://www.box.net/shared/qbhp6i83oc .
thanks!
lynn22,
NickE
« Reply #29 on: July 05, 2008, 06:10:02 pm »
The file is available for download further up in this thread:
http://www.anim8or.com/smf/index.php?action=dlattach;topic=879.0;attach=1027
Pages: 1 [2] 3
