General Category > ASL Scripts
Script Request: untriangulate faces
benzjie:
a: it may take a while
b: you have to make a new attribute called tolerance.
gattispilot:
I get this error:
Error on line 44: undefined indentifer 'attribute'
error on line 44: ';' expected
davdud101:
How do i... USE a script file? It makes absolutely no sense to me at all.
Kubajzz:
First, read the "Installing plug-ins" section on the Scripts page.
Once you install a script, re-start Anim8or. If the newly installed script is a "Command plug-in" (such as the Untriangulate Faces), there will be a new item in the "Scripts" menu. When you install a parametric-mesh plugin, a new button will appear in the left panel in Object mode and when you install an export plugin, a new option appears in the "Export" dialog box... That's it :)
Jdez:
gattispilot: are you using version 0.97 preview? 0.95 doesn't support attributes.
Navigation
[0] Message Index
[*] Previous page
Go to full version
