aquarium
General Clivis:
thanks,
no the fish are 3d models i draw them with line en then use extrude path to make them
to adjust the sand: is it just pulling some points down?
i will try to find en understand the thing you said floyd86 but i will need some time for that.
thanks again
kreator:
You might want to stick a thermostat and thermometer, in the scene then add a filter ( perhaps undergravel ) and pump, then animate the bubbles, finally some lighting to the canopy then it`l look really cool !!
General Clivis:
yeah that might be cool.
but my pc is now working allready so slow.
but i will try.
hihosilver:
Just to clear this up, since I've seen it multiple times, the IOR for glass is actually somewhere around 1.5 but of course it varies with different types of glass. 1.33 is actually the index of refraction of water.
floyd86:
--- Quote from: hihosilver on November 23, 2008, 05:30:19 pm ---Just to clear this up, since I've seen it multiple times, the IOR for glass is actually somewhere around 1.5 but of course it varies with different types of glass. 1.33 is actually the index of refraction of water.
--- End quote ---
It is? It's says 1.33 in the art preview section:
--- Quote ---'IOR - the index of refraction. This represents how much light is bent as it enters or leaves a transparent material. Useful values include 1.0 (air - no difference than outside of a material), 1.33 (glass), 1.49 (Plexiglas) and 2.42 (diamond).'
--- End quote ---
Navigation
[0] Message Index
[*] Previous page
Go to full version
