Box mod wip - Hand
hihosilver:
Francesco, that's great you're taking initiative! That will definitely pay off. You shouldn't necessarily follow all tutorials step by step, that doesn't help you at all. The tutorials are there to teach you the concepts and methodology not how to follow something step by step!
So I think that's a good thing :)
As for the bones, whatever you find is best for animating, though there are certain ways to create the mesh and rig the figure that will allow for less deformation.
headwax:
Yep hiho is right as always ;)
The first thing I made with the Joan d'arc tutorial was a surfboard and fins.
Francesco:
Yes, that tutorial is great, and that website has a lot of other interesting tutorials.
Between a read and a snapshot render, here is where I am about now. I modified the topology and actually narrowing the palm-side creases of the fingers helped a lot, just like suggested by headwax. The change suggested by hihosilver helped to fix the thumb part of the palm, along with two additional bones. I've also fixed the upper part of the palm, more or less I followed the line where the base of the fingers bend.
I attach some images and a video.
The video is inside of the zip file, it's a 320x240, 6 secs video at 8fps. The name is self-explanatory: it shows the point of view of a fly while flying around a closing fist. You might safely assume that the weird coloring is a shift-effect due to the high speed of the flight (it had to be a superfly).
Enjoy!
BTW: I think I know what I have to fix further, but this involves rigging from scratch because it needs more bones and a different skinning. I didn't show any detail about rigging and skinning, but you will notice where and why the hand fails in its realism.
hihosilver:
That's a great model! Especially for someone new to the 3d world.
Can you post an image of your rig? You make it sound complicated to me ;)
Good job so far though, I like what you have.
Francesco:
Thank you hihosilver, you're too kind, really. Maybe I look like the smart guy who plays dumb, but I can assure you that this is just the good luck of a starter - and by the way, I used a reference image, of course, along from stealing ideas here and there from the tutorials and from all of your works people.
Here are the rigging and the skinning problems, my internet connection comes and goes, I'm attaching the pictures and editing this post to make the short story long...
...so here is the edit:
Skinning image:
Left image, the oval on the first joint of the thumb shows where it still bends wrong, and the other highlight shows where the skin makes a weird line when the thumb closes in.
Right image: the top side of the fingers curves while there should be a straight line following the bones.
Also in the upper palm, there should be a bend where marked by the red circle. This is where I'm planning to add bones to keep the volume.
Rigging image:
So far the two bones added to give volume to the thumb's base are working fine.
The other two bones highlighted in the rigging image show how I rotated them to help the hand to close better, moreover to avoid the back from staying all on a plane, when the fist is completely closed.
Looking forward for your advice, thank you very much for your help people.
Navigation
[0] Message Index
[*] Previous page
Go to full version
