Author Topic: Strange effect...  (Read 17627 times)
Strange effect...
« on: June 24, 2009, 06:08:41 pm »
Attached is a file and a render that some of you may find interesting...
I was attempting to create a reflective basketball, as I was trying to make a sort of trophy looking thing...
Didn't do a very good job, but I got an interesting result...
lizeal93
  • Coool!
Re: Strange effect...
« Reply #1 on: June 24, 2009, 08:16:51 pm »
cool can we see the texturing and settings for ART in the material editor.
great effect!
-Albert Einstien
« Reply #2 on: June 24, 2009, 08:26:41 pm »
Uh... well i'm not very good at portraying information in printscreen format... but the model is attached to my first post, you're free to take a look at that if you want to. :)
« Reply #3 on: June 24, 2009, 11:06:45 pm »
That looks pretty nice.  The texture is a bit low quality, if you could make it better quality that would be preferable.  Also, your bump map should be inverted.  The grooves in the basketball should go in not out as they are now.
« Reply #4 on: June 25, 2009, 09:41:07 am »
Looks good, maybe use the same map you used as a bumpmap as a specular map. This will make the ball less shiny, not like it's made of plastic....
« Reply #5 on: June 26, 2009, 09:06:49 pm »
Well i've reversed the bump map, and here's the result, thanks for the tip.
Might conduct a few experiments with this a little later.
xalener
« Reply #6 on: June 26, 2009, 10:26:38 pm »
I would apply the map to a sphere with already high divisions instead of a subdivided default sphere. This will let you get rid of the texture flaws on the top and bottom of the ball.
TheMasonX
  • The gorgeous S&W Colt 1911
« Reply #7 on: June 28, 2009, 08:25:59 pm »
I think the problem is that you're only attribute is reflection. Another attribute, Ks provides the data on how reflective it is. 0 is no reflectivity, just the base properties, and 1 is a perfect mirror. You probably don't even need the outer layer, just the basket ball, and a Ks of .05 or something small for only a slight reflection.
« Reply #8 on: July 05, 2009, 12:40:05 am »
 Would make a better cricket ball with those heavy seams. ;)
