Alloy [Chrome] In Progress
<< < (3/3)
Ratticis:
And i just noticed, i don't see any bolt holes. How's the wheel supposed to stay on? :P
kreator:
Perhaps its like Formula1 Cars, One Nut in the Centre of the wheel ( note: Centre spelt correctly for the sake of UK users and Tyre )   ::)
ENSONIQ5:
If the wheel is of the single-nut type the central hole should be splined (usage of the term "spline" in this instance refers to the engineering method of cutting grooves around the inside edges of a drilling which locate with corresponding ridges on the axle to prevent rotational slippage, rather than the graphic "spline" used on this site to refer to a method of creating a curved line).  It may already be so modelled, it's a bit hard to tell on the render.
Ratticis:
But if it was, the tire would be a slick
onespirit5777:
If it doesn't destroy your work, try sub dividing. Always make a copy, create a new object and paste it there - do this before you make any changes.
Navigation
[0] Message Index
[*] Previous page
Go to full version
