Pages: 1 2 [3]
Author Topic: GrassTestRender  (Read 58587 times)
Re: GrassTestRender
« Reply #30 on: March 26, 2010, 12:25:03 pm »
The last render looks really great! Very realistic!
Re: GrassTestRender
« Reply #31 on: March 29, 2010, 09:56:23 pm »
I've tried ding to the same technique on a tree. It still needs some tweaking.
daniel99
  • Me : Anim8or RULLZ \m/
Re: GrassTestRender
« Reply #32 on: April 03, 2010, 08:27:42 pm »
Nice grass :)
Mreenav D
  • Anim8or and Mental Ray=Super Cool combo
    • Youtube
Re: GrassTestRender
« Reply #33 on: April 05, 2010, 03:15:01 am »
love the new tree .will you add leaves to it? 1 suggestion is that the lowermost thick branch looks like it has been glued onto the tree.I think it would look better if you could make it come out more naturally.ne ways those were some nice grass renders.Keep it up.:)
Re: GrassTestRender
« Reply #34 on: April 05, 2010, 03:43:23 am »
I know what you mean by the "glued" look, I was mostly trying to ues the script with the branches of the tree, it worked, i jsut cant remember my settings I had it last, so I have to re-tweak it, but no problem. I have been experimenting on trees for a couple months (roughly) now, and I do love the comments (at least I know someone likes my work). Thanks  ;D  I Might have a new update soon, I'm seeing if I cant get an animation done that involves using grass and trees.
Cheers to you!
justletgo
Re: GrassTestRender
« Reply #35 on: April 24, 2010, 09:12:57 am »
oh great grass god, which version of the meshtomesh script do you use i've been trying to get meshtomesh6wnfitt to work in anim8orv.097d with no luck. i planted my grass by hand for my first animation and would like that acres of grass feel to the next one.
fantastic tree and grass render, did you get the valley finished?
Re: GrassTestRender
« Reply #36 on: April 26, 2010, 05:13:25 pm »
very realistic render!!
Re: GrassTestRender
« Reply #37 on: May 03, 2010, 02:45:16 am »
Unfortunatly, no. I still have that crappy graphics card, and it cause anim8or to crash many times, so I went with a hill so you couldnt see too far, but even that cause anim8or to crash. so I ended up taking out some grass and lower the res for the video.
I'm pretty sure I took the mesh2mesh_5_wnfi_final, then edited it.
I'm glad you liked it. I have been working on ways of making it look denser, with out the lag from my computer.
But in the end, I guess it will come down to a couple mother boards and a whole lot of sli supported cards to go with it  ;) (and of course the empty wallet)
« Last Edit: May 04, 2010, 03:22:06 pm by cooldude234 »
Josmic8or
  • anim8t & celebr8t
    • JOSIAHSTUDIOS
Re: GrassTestRender
« Reply #38 on: May 04, 2010, 12:49:34 pm »
Now that's what I call
GRASS!!!!
Re: GrassTestRender
« Reply #39 on: November 26, 2012, 05:45:02 am »
Cool Grass render,
to maker FUR/GRASS  i use texture "alpha channel"  and "Script: Copy "Source" mesh to "Target" mesh " by Nickie
http://www.anim8or.com/smf/index.php?topic=184.msg11394#msg11394
script (mesh2mesh_5_final.txt ):
http://www.anim8or.com/smf/index.php?ction=dlattach;topic=906.0;attach=1059
Re: GrassTestRender
« Reply #40 on: November 26, 2012, 02:09:06 pm »
I found that using a textured plane as grass made it look more fuzzy, which is excellent if you're looking to do fur, but unfortunately that's not what I was looking for when it came to grass, and in order to get a good fur result from using many many polygons, it would take millions and millions of millions of polygons to achieve the desired result, which in the end would just be too slow.
Pages: 1 2 [3]
