Author Topic: Scripts Request: Edge to point or Faces to point!  (Read 70563 times)
« on: July 27, 2010, 07:47:12 pm »
hi guys, somebody can maker this scripts? :)
are simples scripts i think then make changes in "POINTS to EDGE" script
this is possible..i try but i dont can make.. :'(
1 -  Edge to point ;
2 -  Faces to point;
one of two, already help me..
some moments i need make this selections..but anim8or not has this functions..
thanks so much all!
Gyperboloid
Re: Scripts Request: Edge to point or Faces to point!
« Reply #1 on: July 28, 2010, 10:24:26 am »
Hi neirao! :) I tried this and had the same result, but then realized that it's not a bug :)
« Reply #2 on: July 28, 2010, 01:26:29 pm »
ohh! thanks Gyperboloid!! :)
yes im try your way work..(but i think then Anim8or should make this turn automate..)
but thanks you help me so much
I tested turn to "points" and work too, and remove edges and points!!
 i needed this function! thanks!:)
Gyperboloid
« Reply #3 on: July 29, 2010, 08:45:00 am »
You wellcome ;) And neirao, one question: what prog do you use to create all these explanations? They are very nice :D
« Reply #4 on: July 29, 2010, 12:24:34 pm »
hi Gyperboloid!
i use CorelDraw, i make printscreens and paste/crop
inside of CorelDraw, after export in .jpeg.  and send to ImageShark.com.
thanks! cheers! :)
« Last Edit: January 13, 2011, 04:50:20 pm by neirao »
« Reply #5 on: January 06, 2011, 05:57:18 pm »
Nobody can maker this script?? :(
this is usefull for use with other script(not only delete points..)like:
- merge points
- flatten points
- move points etc..
« Last Edit: January 13, 2011, 04:51:29 pm by neirao »
NickE
« Reply #6 on: January 13, 2011, 04:13:01 pm »
Neirao,
Attached is a script to do what you requested.  It will select the points of any edges and/or faces that are selected and de-select the edges and/or faces that were selected.
Edges and Faces are both handled by this single script.  I originally wrote a script for Faces and another script for Edges, then realized that there should not be a conflict having them in the same script.
Enjoy!
« Reply #7 on: January 13, 2011, 04:27:24 pm »
UHUUU!! :D
was what I was needing! ;D
Thanks Nicke!! :)
« Last Edit: January 13, 2011, 04:47:05 pm by neirao »
Gyperboloid
« Reply #8 on: January 14, 2011, 05:04:49 pm »
Thanks to Steve we ( actually you guys ) can make a lot of interesting scripts  ( I wonna learn to write scripts too ):)
But neirao, you can do it without script, as I told you before and I think it's more quick ( so finaly, Anim8or have this "functione" ;D)
Select edges and just switch to points, as you already know . And the other is from faces to points like this: select a face, hit "t" shortcut ( or edit=>select=> select face edges ) and then switch to points ;)
« Reply #9 on: January 14, 2011, 07:48:17 pm »
hi Gyper! Thanks! :)
the VISUALIZATION no is the right..
but yes, your way realy work,
Thanks! ;)
Gyperboloid
« Reply #10 on: January 15, 2011, 08:21:20 am »
 ???You mean my explanations are not so right writed ??? Yes I know ;D
« Reply #11 on: January 15, 2011, 08:54:07 am »
Oh no Gyper.. :D
not is "your explanations".. they is very good, i understand all ok :)
is the "Anim8or visualization" then no is right,
Anim8or should "show the points selecteds" in this case..
Sorry is because, im not "speak" english very well ok! ::)
im brazilian..
« Last Edit: January 15, 2011, 08:56:05 am by neirao »
Gyperboloid
« Reply #12 on: January 16, 2011, 04:21:19 pm »
First , I don't speak english well too :D Second, I am very lazy ;D . But I think evrybody can understand what I mean. If you mean the pictures I posted, I think I know what you mean. The third pic, yes ? If so then , there is one thing : when you ahve selected an edge and then you switch to points, the edge is still showed selected ( white ) but actually the points are. Never mind, you understood and I don't think there will be a problem if some newbie will read this. One is sure : we have learn some english here  :D
« Reply #13 on: January 16, 2011, 06:05:23 pm »
benzjie
« Reply #14 on: April 01, 2012, 04:07:02 am »
bumping this " old" topic.  But is it possible to have a script that lets you select edges ( q or Q)  and than select the faces ?
( select two rows of edges wityh q or Q , script selects the inbetween faces)
This would come in very handy whilst UV mapping.
