General Category > ASL Scripts
.STL Export Script
<< < (2/2)
kreator:
Drew, its the same on that Raxx wrote!... Looking for an import .STL to anim8or as well as .ply(export/Import)
it won`t do groups as AlecJames states only single meshes I found
captaindrewi:
doh!..sorry about that :-[ and thanks for the script raxx. :)
AlecJames:
Export STL script: At first I had problems with missing faces (the 3d printer software showed about half of the faces missing).  I found that if I "FlipNormals" so that all faces selected yellow on the outside surface of the object, the stl export worked fine.
A
Raxx:
Yes, you need a continuous manifold in order to expect proper export. This means all faces must face outward (yellow), and not have any holes in them.
Also, it's true, I didn't include grouped mesh support for some reason. I fixed this just now, and you can get the updated script with working groups by using the download link in the original post.
benzjie:
wrong thread :P
Navigation
[0] Message Index
[*] Previous page
Go to full version
