New Idea, New Team
spicy:
Right then! A whole day work to do! I am going to create land using terranim8or add texture, ruffle it out a bit, add the city and some objects. Search till I die to get some good futuristic textures and hopefully show you some REAL images rather than the bad copy of the lamp! Still thinking of some design ideas for the buildings. Where do you get your textures from? Anyway, i shall show you my REAL work later this week (Cross my fingers! If I do it in time!). Though I don't understand how you texture with UV Mapping Classic, help please? Thanks
DressedForSucess:
That UVMapper sounds awesome. Ill look it up. I need a sea texture that needs to be absolutely huge or incrediably detailed ...
What ive used to make my textures look unstretched is simply (on version 5) select the model, go to Settings>Component>TextureUV ... There you can experiement. Or simply click on the UV button on the main interface tools ...
I will check out UVMAPPER as well
Lamp looks good. Cant wait to see some textures ... and Avenic completed in general :P
Im still modelling Bridge Island at the moment. Im nearly there.
I did some experimenting today ... I made some leaves :)
and added the rocket towers and the lever mechanism pods for the railcart rail and walkway lower-and-lift mechanism ... (complicated, part of a puzzle ...):P
thecolclough:
dressedforsuccess, those renders you keep posting are brilliant! i'm not sure that the plant thing really fits in with the industrial theme you seem to have going in the other pics, but it's a nice plant anyways :)
hihosilver:
You're doing a great job on this progress!
Another UV mapping program I'd suggest is Lithunwrap. It's free as well, but the upside to it is that you can actually view the model in realtime as you unwrap it, unlike in UV mapper classic (you can do this in the pro version, but that costs money.) So I'd check it out, you can find it here!
DressedForSucess:
Thanks for your comments. The tree is going to used on a cliff side that will be positioned underneath the main tower ... There will also be distant mountaisn, etc, with tropical jungle-like trees in the background :)
Thanks for the Lithunwrap link :) ill use it ...
Thanks again
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
