v0.97e Pre-Beta
captaindrewi:
I tried to mention this before but wasn't quite sure ...... when using the new mirror tool, if i try and select a point in front view i can only select points at the perimeter of an object with the single pointer selection
i can use the rectangular lasso and select the point or if i tilt the view i can select with the single pointer then
don't know if this is a known bug.
Raxx:
I can't seem to duplicate this, when trying it on a sphere such as yours. Are you sure you don't have front/back modes enabled/disabled, and that you aren't actually selecting the points directly behind the front ones?
captaindrewi:
front/back mode is on default so just expect it to select point in front.
ah it does select the point but for some reason it doesn't appear highlighted in front view, if i view in two ways say front and perspective it does...
oops! it does the same without mirror selected
and in the older D version too...so definitely not a bug in just E version....just never noticed before.
SpeedLow:
windows xp try
http://www.winmatrix.com/forums/index.php?/topic/19718-original-vista-snipping-tool-sticky-notes-inkball-games-for-xp/
or
interix or cygwin in wine mode
Raxx:
Not sure how that information could have helped.
The winXP problem was fixed in v0.97f. Locking topic.
Navigation
[0] Message Index
[*] Previous page
Go to full version
