General Category > Ongoing Anim8or Development
Changed to Older Releases [builds 1162 to 1230]
<< < (63/137) > >>
ronaldefarmer:
Has anyone noticed a problem with the twist modifier in build 1163?
captaindrewi:
Yeah it flattens things at the top.
so that be a bug.
Steve:
Yes, it's a bug.  Happened in build 1125.  I'll fix it, thanks!
Fixed for next update: #098-063 - Twist modifier is broken.
Trevor:
ok, Something broke in 1163... If a 4bit bmp is in the texture list and an8 tries to load on startup an8 will crash with an illegal opperation in glu32.dll.
So, while being able to import while running, if you close and re-open it will crash again like before and what others have posted.
Please see the following post for more info on bmp.
http://www.anim8or.com/smf/index.php/topic,5088.msg37797.html#msg37797
Trev
Found another bug, Local Lights dont work.
Infinit and spots work, but local dont
Steve:
Fixed for next update: #098-064 - Multiple 4/16/32b bitmap formats aren't supported.
Details here: http://www.anim8or.com/smf/index.php/topic,5088.msg37828.html#msg37828
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
