Mixing Morph Targets in Scene and saving in Object mode?
<< < (6/6)
Nellucnaiv:
Hi Kevin,
I have attached 2 morph attempts in a zip folder.
The first noted that it was successful and output an ersect file but the second with all frames checked the same and the object named "Lady", there was no output.
Thanks for taking the time to check my morph_int.an8 files and the one output ersect file. I appreciate your time!
Kevin Gales:
It turns out the problem was the structure,I followed a schema of recent versions I neglected it will be dynamic...anyway you're using an older version of anim8or so the whole structure broke...So I fixed all the problems..basically buffering the whole file, structuring it according to my own parser, then performing calculations point to point..Still does within a the blink of an eye.You can download the update.
Also update your Anim8or version..Anim8or has improved a lot since that version.  8)
Nellucnaiv:
Thanks so much Kevin! You're an absolute genius!
I don't take anything for granted so I am humbled.
I have tried some of the newer versions of Anim8or but stil like 0.98 for its simple interface.
I'll definitely download the update!
Thanks again!
Nellucnaiv:
Just to update you Kevin, you're a Master!
As you said, your "NiftyTool" puts the new morph target out in a split second. You created an awesome tool!
Great job! It works beautifully and no glitches.
You've made me very happy.
Thanks for all your efforts! 🙏👍
Kevin Gales:
You're welcome  8)
Navigation
[0] Message Index
[*] Previous page
Go to full version
