sketch-based modeling and Anim8or
			MatejMakesStuff:
			Woah that's creepy!
			ianross:
			I created the following images, using an AI application,monstermash and anim8or. 8)
Firstly, I asked the AI app to create a woolly mammoth side view. Then I traced around the image of the mammoth in monstermash and it inflated into a 3d model.
The 3d mammoth was then imported into Anim8or, the 2d backdrops were created in the AI online app.
			2020 Hindsight:
			What AI did you use? I've never seen a mammoth with tusks pointing down :)
I guess you treated the tusks like legs in monstermash to get two of them? Or did you add them manually?
It looks good! Is this part of a larger project?
			ianross:
			Thank you Hindsight you are right the tusks should be pointed outwards, please see the below changes.
There are many apps that can be used to create AI, here is a websites that is a good starting place.
https://perchance.org/ai-text-to-image-generator
The mammoth images have been created for educational interest for the anim8or forum. 8)
			2020 Hindsight:
			Thanks for the AI link. I've just had a little play with it - it is good! Although it seems to get a bit confused with fingers (see attached image).
Your mamoth looks right to me now.
I wondered if you created the tusks like the legs in monstermash. But I guess you must have added them manually?
Navigation
[0] Message Index
[*] Previous page
Go to full version
