v0.97b Preview Ready
Steve:
KiwiNM8OR, are both of these with v0.97b but with multi rendering off and on? Or is the "Before" one with v0.97a and the "After" with v0.97b? I did fix a couple of reflection problems for the v0.97b release that could change the result like this.
KiwiNM8OR:
1st image 0.97a Art Ray Trace non multi
2nd Image 0.97b Art Ray Trace with multi
I like the new renderer. With some tweaking of the lights it turned out thus:
mrpete:
Good job Steve adding the background color as an environmental variable to ART. The results look pretty good when the final rendering is complete. I also enjoyed layering the materials to create extra depth in my meshes with the ART mode as well(though rendering was longer as expected). I did this with the earlier version of Anim8or as well but even with this beta version the results are very pleasing with just the built-in checks texture and a few malformed spheres that I built to test out the ART modes. The image and coloring contrasting is true to what I am actually rendering. Especially, when I am using the lower AA modes to get a crisper picture in the final rendering.
GOOD work, Pete ;D
VBSmiles:
Don't know if this problem is new to the version or a pre existing problem. But do understand that there is existing problems in Windows Vista.
Anyhow, Drag Selection doesn't seem to 'refresh' the screen while selection is being made. It does however make the selection and refreshes afterward.
Tanzim:
VBSmiles: that problems already been reported on the General section, to fix it just 'Disable Desktop'.
To do this: right click on the Anim8or.exe, go to properties and then Compatibility, there should be a check box saying "Disable Desktop", check it.
Navigation
[0] Message Index
[*] Previous page
Go to full version
