General Category => General Anim8or Forum => Topic started by: thecolclough on September 23, 2021, 12:35:55 pm
question for Steve...
i've got a scene with several lights in it, and some of them don't seem to have any effect in the workspace. in particular, i've got two with identical settings, and one has a visible effect in workspace (the greenish light which can be seen in attached image 1) but the other doesn't (image 2). so i was wondering, is there a theoretical limit on how many lights we can have in a scene? or is there a limit on far you can nest parent-child relationships between elements before it starts to affect light behaviour? or maybe something else which i haven't thought of ???
i'm running build 1402 on Windows 10 Pro version 2004
The workspace only supports 8 lights. It's a historical limitation from the origional OpenGL. I'll look into reaxing that limit.
ah, ok. pretty sure there are 10 in the scene now, so that explains that.
they'll all show up in the render though, right?
They should show up in the render, unless it's using OpenGL
i'm working on test renders now and the lights do all seem to be showing up correctly.
thanks Steve :D
