Author Topic: 2 requested scripts  (Read 48711 times)
Darkjesture
2 requested scripts
« on: September 20, 2008, 06:52:12 pm »
I would like a better point snap tool. Would that be posible to write in a script?
And also i would like an md2 mesh export script. Just a suggestion really doesnt even have to be a script.  :)
Re: 2 requested scripts
« Reply #1 on: September 21, 2008, 07:53:03 am »
What exactly do you mean by "a better point snap tool"?
Darkjesture
« Reply #2 on: September 21, 2008, 11:12:18 am »
I have trouble snapping points unless i have them litterally on top of each which is kinda problem because a like to to model in the style where you lay each polygon out then you mirror your half and that means i have to work extra hard to line everything up just so that i can take a shortcut and snap a couple of points together.  :)
« Reply #3 on: September 21, 2008, 01:22:41 pm »
Ok.... I'm not really sure if I understand...
What should the script do? Move a point to the position of the nearest neighbour and merge them? Or something like "intelligent mirroring" (the script would mirror a mesh and merge the corresponding points automatically)?
Darkjesture
« Reply #4 on: September 21, 2008, 01:43:32 pm »
I want to be able to take 2 points and join them into one point.
« Reply #5 on: September 21, 2008, 01:45:52 pm »
Then you can use the "Merge Points" command (hotkey Shift+L).
Darkjesture
« Reply #6 on: September 21, 2008, 03:01:33 pm »
I know that you  can do that but it sux to use i want something that will work on the points at a much greater distance.
« Reply #7 on: September 21, 2008, 04:16:46 pm »
Simply move the point together or typ in a greater value in the merge point window: default is 0.500, make it 2 or something (depending on the distance of the points). But it's better to move the points closers together and then merge points, especially when working with more points.
Claude
« Reply #8 on: September 21, 2008, 05:39:28 pm »
Try this to move the point and then the merge function:
« Last Edit: September 21, 2008, 05:41:16 pm by Claude »
Darkjesture
« Reply #9 on: September 21, 2008, 06:38:52 pm »
Thnx will try that rite away! :)
Darkjesture
« Reply #10 on: September 21, 2008, 06:49:05 pm »
Sry for the DP.
Thats exactly what i waslookinf For!!1 :) Thank YOu!!!
