Author Topic: warp modifiers  (Read 10528 times)
warp modifiers
« on: October 12, 2008, 12:58:53 pm »
i made about 5 cylinders (made 1 copied 4 more), grouped them and when i go to bind the warp modifier they all disapear. what happend?
Re: warp modifiers
« Reply #1 on: October 12, 2008, 03:10:45 pm »
First, I think this topic belongs to the "preview" board...
I've done some tests and this is what I found:
Modifiers work ok with almost any kind of shape (for example a cylinder is automatically converted to mesh...), but there's a problem with groups. If you bind a modifier to a group, the group disappears; it's not deleted (unless you delete the modifier...) and you can bring it back with the "unbind modifier" command. The "effect modifier" command doesn't work.
I think you'll have to join the shapes before using a modifier instead of grouping them...
Re: warp modifiers
« Reply #2 on: October 12, 2008, 03:13:40 pm »
ok thanks for the help
