Author Topic: possible script; desubdivide faces?  (Read 18292 times)
inky84
« on: August 18, 2009, 02:39:44 pm »
well, obviously, I'm new here, but I was wondering if there was a working script for "desubdividing" faces in anim8or.
I've seen two called "poly reducer" and "untriangulate" but they both have the same errors strangely. (the triangulate script on this site works fine.) So, I was wondering, if there was a working script out there, or something at least. my object has WAY too many faces (440320) and takes up 73,900,000 bytes
« Last Edit: August 18, 2009, 02:43:42 pm by inky84 »
odp04y
Re: possible script; desubdivide faces?
« Reply #1 on: August 18, 2009, 04:12:09 pm »
There is a script called unsubdivision that does this, try searching for it in this section.
inky84
« Reply #2 on: August 19, 2009, 12:06:55 am »
okay, I got that too, but they all have the same two errors.
line (insert number here): sign ";" expected
(same number as before): undefined identifier "attribute"
I figure these are simple errors, but it's weird, because all THREE of them have the same errors.
I'm using the latest version (0.95c), so maybe it's something wrong with that?
« Last Edit: August 19, 2009, 12:11:00 am by inky84 »
« Reply #3 on: August 19, 2009, 12:22:39 am »
0.95c is hardly the latest version. Make sure you have this: http://anim8or.com/download/preview/index.html
inky84
« Reply #4 on: August 19, 2009, 02:22:32 am »
okay, that's helped a little, but for some reason my two models specifically won't  unsubdivide.
I could put it up here, I suppose.
« Last Edit: August 19, 2009, 02:26:22 am by inky84 »
dajean
  • Creativity
« Reply #5 on: August 19, 2009, 03:50:24 pm »
Iguess you could expor it to a different format (e.g .3ds, .obj) into another program that can unsubdivide your model and then import it to anim8or again.
inky84
« Reply #6 on: August 19, 2009, 03:56:33 pm »
any suggestions?
edit: merging points seems to have created some success.
« Last Edit: August 21, 2009, 12:35:07 am by inky84 »
