Author Topic: enviromen map texture problem  (Read 13659 times)
moameen_15
« on: February 18, 2008, 05:19:16 pm »
Hi ,well i am having a problem enviroment map textures are not working,the images are sqare,256x256,but its one image being repeated,anyway i do the usual thing and chose the images but when i apply the texture to the object it stays the usual old gray colour ,no change,normal textures work and images put on difuse work but not enviroment map,please help me
moameen_15
Re: enviromen map texture problem
« Reply #1 on: February 18, 2008, 06:19:38 pm »
Ok its just an XP problem
« Reply #2 on: February 18, 2008, 07:38:49 pm »
My guess is you don't have shaders turned on.  You can turn them on by going "view>preferences" and checking "use shaders".  But the environment map should show up when you render otherwise.
moameen_15
« Reply #3 on: February 19, 2008, 07:27:27 am »
yip u right its not checked,but the box is grey and i cant check it
« Reply #4 on: February 20, 2008, 02:53:51 am »
It sounds like your drivers don't support OpenGL or something of the sort.  You can try updating your drivers, but they may just not support it.  If so, you can view your environment maps by rendering the image.  You can do this quickly in object mode by going "Render>Render Image..."  It'll give you a quick render of the viewport without shadows or anything, so it should go quickly.
moameen_15
« Reply #5 on: February 20, 2008, 05:27:06 am »
i think my drivers just are not installed properly cause it works on win98 on the same computer ,thanks though,it does render with the enviroment map
