Author Topic: Need Help Fast  (Read 15218 times)
Paykoman
Need Help Fast
« on: December 01, 2009, 02:43:44 pm »
Hi guys i'm new here. I Make my 1st project but when i finish that i save it with ext .an8 but all time i open the file all my work are not 100% like somethings going on and go back in the process and i need re-make everything. Wt can i do to dont happen this?
Ty and i'll w8 for answer.
Re: Need Help Fast
« Reply #1 on: December 01, 2009, 05:00:31 pm »
I think you should be a bit more specific... Try to describe your problem in more detail, or upload a screenshot if necessary.
Pincho
Re: Need Help Fast
« Reply #2 on: December 01, 2009, 05:29:49 pm »
Never had that happen. However, you may be looking at the wrong Object. There is an Object list, and it could be that you have your finished model further down the list.
Paykoman
Re: Need Help Fast
« Reply #3 on: December 01, 2009, 05:57:17 pm »
Ty m8 but i already can do it right.. Only use a newest version of the program ;)
Ty for help
Re: Need Help Fast
« Reply #4 on: December 01, 2009, 08:20:34 pm »
Paykoman ---
When you say "...i save it with ext .an8...," what do you mean, exactly?  Whenever you save an Anim8or project file, it will automatically append the ".an8" extension, you don't need to specify it.  Are you actually typing in the ".an8" extension when you save the file?  If so, why not try creating a new project and just specify the base name of the file when you save it.  Also, have you set up your Anim8or directories properly (File > Configuration)?
And before anybody else brings it up, have you read the manual, yet?  That's always the best place to start, and keep as a reference.
« Last Edit: December 01, 2009, 08:26:47 pm by RudySchneider »
