Author Topic: Windows Vista Save Glitch  (Read 24963 times)
cfive
« on: March 06, 2008, 07:56:34 pm »
First off, I love anim8or and congrats on such winnerly software! Anyway, when I got Vista, I was annoyed how anim8or (and 50 other programs) didn't work right, one day though, after putting it in compatibility mode for windows 95 I somehow got it workin (though I don't think it did in that mode before) I was pretty pleased until I hit the "Save as" button, which is when I got something like this:
I noticed however, that the texture file I had downloaded would infact show up so I copied that and saved over the copy. Anyway, can this be fixed in v.96? (This also happens on the export, too)
Re: Windows Vista Save Glitch
« Reply #1 on: March 06, 2008, 08:04:14 pm »
Anim8or just calls the standard file save dialog function in Windows.  It has a "*.an8" filter by default and an option to choose "*.*".  I would think that Vista would behave the same as Windows in this respect.  I'll try it on a Vista computer to see if I can see something.
cfive
« Reply #2 on: March 06, 2008, 08:33:20 pm »
GREAT! Thanks for responding. As a note, like I said I was in compatability mode for windows 95.
flametiger74
« Reply #3 on: March 06, 2008, 09:25:27 pm »
Hey. I've been using vista for about 7 months now and I noticed a pattern with new programs to vista.
1. They either won't work or work glitchy.
2. After setting the compatibility mode to many different things it starts working better.
3. Works fine. I don't even have to use compatibility mode anymore.
I think that over time the problem fixes itself because of vista being updated constantly.
Try going to windows update. (just search for windows update in the start menu.
Make sure all your graphics drivers are up to date. (Just go to your graphic card manufacturers website.)
When I started using anim8or on my computer it was very glitchy, now it works absolutely fine.
If the problem doesn't get fixed I suppose that you just wait it out, because remember- Windows Vista is really (even though Microsoft thinks not) is at a beta version for compatibility to other programs.
Just to let you know. I've installed games on my computer that were meant for Windows 95 and 98, and they run perfect. After a couple years I bet nobody is gonna' have a problem with Vista anymore.
« Reply #4 on: March 07, 2008, 05:57:45 pm »
You also might get things to improve by upgrading your graphics driver.  There are many little bugs in pretty much all Vista graphics drivers for OpenGL but they are continually being fixed.
« Reply #5 on: March 08, 2008, 03:04:37 am »
from jan 4
what I do: To save files: when you click the edit>save file as you will be given a small window entitled "Pick a File"
There will be three boxes. The small top left one will list your direcory you are working in. The right one will have "search" greyed out. The bottom one which is the largest  might say 'This Folder is empty". This is where you would expect to save files.
To save a file you have to click on the top left hand box. Then push your keyboard key "end". this will take you to the end of the directory structure. Here you type a backsslash and the full name of your file ....
You could probably get away without the backslash but I'm not sure as this is how you sepearet the name of your file from the directory stucuture.
Your other alternative is to make a file before hand eg a text file and rename it as an an8 file. You might be able to save over this file if  you can find it.
cfive
« Reply #6 on: March 08, 2008, 06:13:38 pm »
Actually, your alternative is what I use...
