Author Topic: Lighting Effects  (Read 12860 times)
spicy
Lighting Effects
« on: March 11, 2008, 07:23:49 am »
Hello. Say I wanted to make a Lightsaber (From Star Wars) and I wanted the glow on the light saber when it moved and stood still. How would I do that?
Re: Lighting Effects
« Reply #1 on: March 11, 2008, 01:20:27 pm »
Here's a great tutorial to follow.
It isn't specifically on lightsabers, but the concepts can be easily used to make one.
  • Flying Platypus
« Reply #2 on: March 11, 2008, 02:26:13 pm »
The tutorial hihosilver recommended is great if you want to make a nice scene; however, I'm afraid it won't help you if you plan to make an animation - you would have to change the glow filter position thousand times...
If you need a glow effect in animation, I recommend making a coloured plane with high emissive value and transmap so it will fade to transparent from center to the borders - then attach the plane to the lightsaber - and it's done ;D
EDIT - I've searched the old forum and I believe this is exactly what you need:
http://www.anim8or.com/ubb/Forum1/HTML/014575.html
« Last Edit: March 11, 2008, 02:49:53 pm by Kubajzz »
« Reply #3 on: March 11, 2008, 09:35:55 pm »
I agree with Kubajzz, but you will have to make sure the plane is always perpendicular to the camera, no matter what the orientation of the sabre.
