Author Topic: How to zoom  (Read 15162 times)
GreyBubbleGum
How to zoom
« on: June 02, 2010, 04:32:25 am »
I was wondering if there was a zoom buttom. It would be really helpful if there was or if there was a way to zoom in.
Re: How to zoom
« Reply #1 on: June 02, 2010, 04:43:44 am »
There are two ways to zoom: first just moving your camera closer to the object and second you can edit (double click on the camera) the camera FOV (field of view) --> the lower the number the more you zoom in, the higher the more you zoom out. You can set key frame on the field of view by click the button with the three dots behind it.
Bugtrooper
Re: How to zoom
« Reply #2 on: June 02, 2010, 04:50:25 am »
There is an eye button on the top left side of the screen. Click on that to enter view mode. There you can use the non-uniform scale button, shaped like a square with two arrows in it.
Re: How to zoom
« Reply #3 on: June 02, 2010, 04:51:09 am »
Zooming within the workspace is done using the View mode and scale buttons (as highlighted below)  Moving the mouse left and right zooms in and out.
GreyBubbleGum
Re: How to zoom
« Reply #4 on: June 02, 2010, 04:59:36 am »
Thks u guys are soooooooooooooooooooooooooooo helpful
BOB_I_Ts
    • Anim8rOrg
Re: How to zoom
« Reply #5 on: June 03, 2010, 01:30:54 am »
in any mode object figure sequence scene and browser
to zoom in any view port ctrl R  will enable arc rotate click and hold middle mouse (or alt and right mouse if useing 2 button mouse)  with in green circle will "scale zoom" if you hold right mouse out side green circle it will effect zoom angle of prospective view port
