Pages: 1 [2]
Author Topic: Scripts Request: Edge to point or Faces to point!  (Read 76908 times)
lppena
  • Anim8or, does a body good.
Re: Scripts Request: Edge to point or Faces to point!
« Reply #15 on: April 01, 2012, 06:50:11 am »
Neirao,
Attached is a script to do what you requested.  It will select the points of any edges and/or faces that are selected and de-select the edges and/or faces that were selected.
Edges and Faces are both handled by this single script.  I originally wrote a script for Faces and another script for Edges, then realized that there should not be a conflict having them in the same script.
Enjoy!
Thank you NickE. Leroy.
model4me
« Reply #16 on: January 21, 2014, 07:08:31 am »
Hi thank you for the script. I applied  the "convert to subdivided" to a mesh and tried to use the script on the surrounding cage of the mesh. Maybe there is something I am not doing right? It worked fine for me on a normal mesh. If it is not too much trouble could you have a look and try to get it to work on subdivided as well? I am using Anim8or version 0.98. Thanks again.
polyGon_tError
« Reply #17 on: January 25, 2014, 08:41:30 am »
Command Script can't work with Sub-Division, so it will not be possible - model4me
Pages: 1 [2]
