Author Topic: need help with 3D modeling tool  (Read 14299 times)
CoriDavis
  • SammyJ Studios
    • SammyJStudios.net
« on: July 28, 2010, 05:46:53 pm »
is there a detailed tutorial on how to set up the "add edge" tool? I'm trying to model a horse skull like the realistic head modeling and I can't make the edge or any kind of line. as you can see in the picture, I tried starting out with a square, but I can't add on to it.
  • Neirao
Re: need help with 3D modeling tool
« Reply #1 on: July 28, 2010, 06:02:33 pm »
Hi CoriDavis, :)
to start
HOLD SHIFT + LEFT MOUSE CLICK!
see in Manual = http://www.anim8or.com/manual/4_object_editor.html
in "Adding Points and Edges" is easy ok! :) sorry my english..
« Last Edit: July 28, 2010, 06:05:11 pm by neirao »
CoriDavis
  • SammyJ Studios
    • SammyJStudios.net
« Reply #2 on: July 28, 2010, 06:04:37 pm »
Ooooh! thank you so much!
  • Neirao
« Reply #3 on: July 28, 2010, 06:08:20 pm »
you are wellcome!! ;)
CoriDavis
  • SammyJ Studios
    • SammyJStudios.net
« Reply #4 on: July 28, 2010, 06:09:45 pm »
so I got that to work, but the "Extrude Edges" won't do anything, and how do I get rid of that square? I've tried every way to try to delete it
rellik420
    • youtube channel
« Reply #5 on: July 28, 2010, 06:35:53 pm »
u have 2 select an esge of a face. if ur in the wireframe view the line will turn green when u select it.
try filling the holes on ur square maybe then u can select it. or delete the points
h
CoriDavis
  • SammyJ Studios
    • SammyJStudios.net
« Reply #6 on: July 28, 2010, 06:49:16 pm »
Ok, I changed modes after moving the suare and I got rid of it, but when I try to extrude the edge of the line I made, do I just click and drag? is there something special i'm supposed to do? clicking and dragging does nothing, even with an edge selected.
« Last Edit: July 28, 2010, 06:51:29 pm by CoriDavis »
CoriDavis
  • SammyJ Studios
    • SammyJStudios.net
« Reply #7 on: July 28, 2010, 07:15:55 pm »
I got it!!! I had to fill the holes first, that was what I was doing wrong
CoriDavis
  • SammyJ Studios
    • SammyJStudios.net
« Reply #8 on: July 28, 2010, 09:24:59 pm »
Ok, what do I do if one of my squares won't fill in no matter what I do? I tried re-covering the lines in case I had a gap, and it still wouldn't work
Gyperboloid
« Reply #9 on: July 29, 2010, 08:09:52 am »
Maybe the edges are so close, that them seem to be connected, but they are not. I always select the point(s) and merge them to check it up, if I have the same problem. And a sreenshot is always helpfull ;)
